Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Loud clunking noise underneath fridge
I have a Kenmore fridge and will often hear a loud clunk/rattle noise as if something is turning off. Any suggestions on how to fix?
  • Anonymous Dec 30, 2008
    any solutions for loud noise?
  • 93 Answers
Its sounds like a spring is broken inside your compressor this you cannot repair you need a commpressor replacement or you can check if your fridge is levell sometimes by levelling the fridge it may reduce the sound thans from gilles
Posted on Mar 15, 2009
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
Why does my whirlpool refrigerator makes a very loud clunk noise when it turns off
Try looking for any pipes that are rattling against the cabinet , if not, I'm afraid compressor problem.
May 02, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud clunking noise
check engine mountings and front ddie shafts
Dec 30, 2013 | Cars & Trucks
Clunking noise from 09 charger front end
That sounds like a loose exhaust pipe or a metal cover plate underneath that has come loose.Check it out.
Apr 15, 2013 | 2008 Dodge Charger
Bad Problem with solenoid valve.
If the valve noise is excessive, or more than it was originally, then yes, replace the valve.
If the noise is no worse than it was originally, then you may be overly sensitive to the noise its making.
Also, check that the valve has not shifted slightly in such a way that it's opening and closing rattles it against something that it didn't used to rattle against. A sheet metal panel will amplify the valve opening and closing.
Let me know what you find.
Dec 12, 2009 | Honeywell Power Humidifier: Furnace...
Loud clunking noise when i turn a corner both sides rear
check the sway bar kinks for play both rear wheels will have to even ramps work good if you have them if the is any play in the links it wil rattle also check for play in the bushings that the bar goes threw tis will also give you the noise you complain of
May 28, 2009 | 1998 Lincoln Town Car
Temperature not low enough
check fan at the back of refrigerator or you have defrost problem
Apr 05, 2009 | Kenmore Refrigerators
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
711 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
