Question about Maytag Neptune MAH5500B Front Load Washer
Washer squeeks when drum rotates during wash cycle
    Problem Solver:
  • 4 Answers
The 2 bushings that mount the motor to the body of the washing machine are causing this.
You can get just the updated bushings, or a kit of 2 updated bushings and a replacement belt which is probably a good idea to replace as long as you are in there.
Remove the back cover and inspect the job. It's self explainatory and took me less than 30 minutes to complete.....and it worked on the noise :)
Posted on Dec 12, 2008
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Drum or basket rotates 3/4 turn one direction the pauses 10 seconds then rotates 3/4 turn the other direction during wash cycle. Does the same during spin cycle.
This is normal operation for the machine It is doing this to get detergent and water to all of the loaded cloths and also to balance the load for when it is washing and spinning
Nov 05, 2015 | Maytag MAH21PD Front Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Washing machine travels during the spin cycle
Hi - Try to rotate the drum when it is not in use, manually and see if you notice the sound as well. If you do the drum is not balanced and you would need a professional technician to diagnose the bearing and pulley system behind the drum for repairs.
Oct 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Limited agitation during wash cycle Load Sense OK
Possible that the program selected is an easy wash as this is meant for daily wash , less soiled clothes.
If however the same situation is present in all the cycles then the capacitor to the motor must be checked as it can reduce the speed of the motor.
Also check the belt , check for friction on the drum spindle and the motor.
Jul 22, 2011 | LG WT5001CW Washer
Maytag FAV6800AW have replaced clutch and cleaned under tumblers. Machine will not balance. When rotating tumblers entrie drum rotates (during cycle). I removed drum and no leakage out bottom. Does this...
Let?s see if I understand. Are you in a wash/agitate cycle when this happens? If so is the wash basket rotating Clock Wise with the tumblers rotating (washer top raised for observation)? With A Spin Only cycle selected and some clothes in the wash basket. Raise the washer top from the base and observe the wash basket rotation. The wash basket will rotate CCW the spin direction. Do the tumblers rotate while the wash basket is rotating CCW? If so the load will go off balance. What series is your machine it will be the first two digits of your Serial Number i.e. 10 through 17. Was the original clutch replaced because of severe rust of the One-Way Roller clutches/bearing in the clutch Pulley assembly? Do you have the original clutch pulley assembly? Did your machine use the upper the One-Way Roller clutches/bearing ring? Your series number will help me but if you can confirm. I?ll try to help?.Rich
Jan 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
