Question about Singer Quantum XL-1000 Computerized Sewing Machine
Quantum XL-1000 I just got this problem. It was sewing fine before and now all of a sudden, the fabric won't move. The needle moves freely, the feet are moving just fine, everything is threaded right, there's no junk in under the needle beneath the plate. The machine will no longer move forward or backward. HELP! Thanks! Amy
  • 66 Answers
Ok it sounds like either the gear on the rotoary hook is bad "lot of money to fix" or there is a small pin that moves the feed dogs make sure it is setted correctly. also make sure the pressure foot is down all the way.
Posted on Jan 24, 2009
How to unlock the handwheel of my signer quantum xl-1000
Check the bobbin area and make sure there's not a tangle of thread keeping the hook from turning.
Feb 14, 2015 | Singer Quantum XL-1000 Computerized Sewing...
I can get to the adjustment mode on my singer quantum XL 1000, but how do I use it? The numbers 8 and 9 show below the numerical touch pad.
I sounds to me like instead of an adjustment, your machine has been set to end with the needle down instead of up. You need to get the user's manual for it; I'm almost sure that you can program the needle behavior at the end of a seam or color block. Just go to the Singer site--it'a free download, if you don't have one.
Sep 24, 2014 | Singer Quantum XL-1000 Computerized Sewing...
Singer quantum XL-150 how do i thread this machine?
All Singer models would have arrows/numbers to guide your top threading from the spool pin to top thread guide, for most machine start from your thread spool pin, to a thread guide follow arrow down then up into the take up lever and down to the needle thread guide then into the needle hole. Assuming you have wind and install the bobbin thread into the bobbin case, turn your hand wheel towards you makes the needle bar goes down,keep on turning till the needle bar is fully up again, pull the end of the top thread to pick out the bobbin/bottom thread. With your material/fabric under the presser feet, apply the presser feet lever down, you are ready to sew.
Dec 24, 2013 | Singer Quantum XL-1000 Computerized Sewing...
My Singer Quantum XL 1000 is jammed and does not move. The light is on. Please help
Try to turn the hand wheel (on the right side of the machine) backwards ( if you are facing the right side of your machine, turn it clockwise) and try to remove the thread. Once its freed up, change the needle.
Hope that helps,
Chris
Jun 13, 2010 | Singer Quantum XL-1000 Computerized Sewing...
I have a Quantum XL-1 that apparently has a broken timing belt.
I have an Quantum XL 1000 Singer Sewing machine that needs a throat plate. I am in need to find this piece. Please can you help?
Jun 10, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 301A stitch jam
your machine threads from right to left. the needle flat spot faces left. big loopy things means that the upper part of the machine is not threaded properly. as far as the needle hitting the bobbin case, it sounds as if someone removed the hook (part that holds the case) and put it back on 180 degrees off.
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Needle will not move
It's easy
you should adjust the bobbin or the stitch regulator
Nov 07, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Singer Quantum XL-1000 Computerized Sewing Machine Logo
148 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
