Question about Minolta Freedom Zoom 70 35mm Point and Shoot Camera
Don't start properly
When I put the battery the unusual sound create (tik..tik..tik?) for some second .it seems that some gears not correctly roll over and turn. Then the sound stop and all data blank on DATA PANEL without stopping. Then don't work all bottoms. This problem happened immediately without any event. We toke some photo and after bring out from our bag and switch on we found this problem. We didn't use this camera for one year. Please advices us the solution. The camera is Minolat Vira Zoom 70.and serial No. is 36931645.
SOURCE: Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Posted on Dec 14, 2007
informatica
  • 1114 Answers
SOURCE: Instructions for a Minolta Freedom Zoom 70 C Camera
Hi - You can download the manual by clicking the link underlined in blue below:
Freedom Zoom 70 C
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 02, 2008
SOURCE: F stop settings not responding
It could be that the camera's aperture stop-down magnets have failed, causing the camera to shoot everything fully stopped-down (e.g. all shots at F22 or F16). There doesn't appear to be a cure for this (at least not one that makes financial sense). Change the shutter speed over a range, then look into the lens - does it stop down fully every time? Try changing the f-stop - does it still stop down fully every time (the iris goes very small - same size on every shot)?
If yes, it's the magnets. If you've invested a lot in lenses, try a Sony digital SLR - your lenses will work with that, or pick up another Minolta film body - perhaps something substantially newer, where the aperture magnets haven't had a chance to fail.
Posted on Oct 20, 2008
  • 17 Answers
SOURCE: Blinking film on screen.
Sounds like the batteries went dead, and the internal lithium memory battery was already dead, causing it to forget the settings. install fresh batteries, and reset the ISO of youtr film by holding down the ISO button, and pressing the up/down buttons behind the shutter release. That should return it to normal, but you will have the same problem again whenever you are changing the batteries until you replace the lithium cell. To change the lithium cell, remove tha battery pack, and open the metal plate in the camera's battery compartment. The cell is a lithium CR 2016.
If that does not fix it, you may have a broken camera.
-John
Posted on Nov 08, 2008
Obertelli
  • 3006 Answers
SOURCE: the data panel has some black marks in it, can
Your camera is now about a quarter of a century old so model-specific spare parts like the LCD and rubber trim panels are as rare as fresh **** ****. The situation is worsened as Minolta no longer exist. Unless you look for another example for spares then you'll just have to live with the faults, but the discoloured rubber parts (I imagine they've gone from near black to a variable milky appearance) can be improved by using automotive refinishing products. Some exterior vinyl and rubber products work well as do the kind of tyre blacking polishes which dry completely without rubbing off easily. If you look for a replacement/spares donor then check out your local FreeCycle and Freegle groups (the latter is UK only). Many old 35mm SLR's, especially the later highly electronic auto everything models like yours, are virtually worthless so can often be obtained for free these days. I hope that you have found my reply to be of use; please take a moment to rate my answer.
Posted on Feb 28, 2010
Honda Civic 2006 ignition issues
99% it's a bad battery.
Sep 16, 2017 | Cars & Trucks
How a engine works
sounds like the plugs where to long and the pistons hit them when you turned the engine over
Apr 28, 2012 | Cars & Trucks
My Ti-86 wont turn on after i change the batteries
This may sound silly but check that you put the batteries in the correct way round for (-) and (+)?
Feb 17, 2012 | Texas Instruments TI-86 Calculator
My truck turns off when i put on the A.C on or the defoger also the radio turns on and off and when I turn on the truck it has a tik tik tik sound.
Very common problem after the battery has been disconnected or a battery change. Clean your throttle body with throttle body cleaner. First disconnect the battery, clean the TB with TB cleaner, must be nice and shiny. When finished, hook the battery back up and drive around for 20 minutes or so with all accessories off, so the computer will relearn a properly functioning throttle body.
Your computer learned some bad habits, so when you changed the battery, the computer thought the throttle body was clean and functioning properly. So when you changed it, this caused all your problems. Very common, keep your throttle body clean, should be done at least once a year. Total cost if you do it yourself is around $5, for the can of TB cleaner.
Apr 13, 2011 | 2002 Chevrolet TrailBlazer
Motorcycle battery seems dead, help locating/replacing/charging
Yes it is the battery. First try charging it with trickle charger. NOT car battery charger. It should work fine once it is charged enough to start the bike. Than the bikes should keep it charged. Or you can jump it with car battery. This is safe. THe motorcyle battery is also 12 volts. Just smaller.
After the bike runs for 5-10 minutes and shut if off. Wait 5-10 minutes after it is off and try again. If it does not start again, than your battery is either dead or your stator/rectifier (your charge system) could be faulty. Lot cheaper to get battery for $30 than to pay $75 hourly shop fees for testing and than repairing.
May 20, 2009 | 2007 Ducati Monster 695
It wont start , has a click-click -click sound when you try to start it
Try trouble shooting by using another battery to start the vehicle. If it does not start, then the starter must have gone bad.
Rate this please.
Apr 25, 2009 | 1999 Dodge Caravan
Power not wrokign properly
check secondry side of sm txr for shorting
Jan 10, 2009 | SAMTRON 55V 15" CRT Monitor
The starter makes a tik tik tiking sound
the seloind is gone or the battery is down
Jan 08, 2009 | 1998 Dodge Intrepid
Minolta Freedom Zoom 70 35mm Point and Shoot Camera Logo
51 people viewed this question
Top Minolta Cameras Experts
David Payne
David Payne
Harrie
pontelemon
pontelemon
Are you a Minolta Camera Expert? Answer questions, earn points and help others
