Question about First Alert SA302 Dual System Smoke Detector
Low battery chirping sound: changed battery, but still chirping!!
    Novelist:
  • 152 Answers
Try a another new battery sometimes they are no good if they where on the store shelf for to long of course the store wont tell you this. if this dosent work replace the unit its better to be safe than sorry
good luck
Posted on Dec 10, 2008
MY ALARM KEEPS CHIRPING. Thought I should change the battery but discovered it's not battery operated!
A chirping smoke detector indicates low battery! Change battery or replace smoke detector!
Aug 15, 2015 | Home
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
My kidde AC smoke alarm I12020 chirps at night then come daylight it makes no noise
Most "chirping" is indicative of low batteries. Perhaps your smokes are improperly wired through a light switch? As to locating, try using a piece of tape over the sound port to change the sound; with these problems there are often more than one causing it. Check also to see if you have any CO alarms that were plugged into a switched outlet. Most of these also have battery backup. Good luck!
Mar 08, 2013 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
2002 tahoe chirping sound- turn steering to right lessens chirping sound
Sounds like you have a brake backing plate (or something similar) rubbing the brake rotor, or up against the tire or wheel. I would look at that first. It is very likely not the power steering or the pump or belt. You are saying that the chirp is less when steering to the right. Look at the Right front wheel and wheel bearing.
Dec 27, 2017 | 2002 Chevrolet Tahoe
I changed the battery in my smoke alarm and it is still chirping. What can the problem be?
Use a quality battery duracell or energizer. Not ones from the dollar store.
Chirping means low battery.
Jan 25, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
BRK smoke/co2 detector - won't stop beeping
sometimes the alarms are ganged to other apartments .. that's so if there is a fire in one apartment then others are alerted as well .. so the low battery warning could be from a neighbor ... also there may be a common ceiling space that will allow you to hear your neighbors detector .. at any rate someone around you has a low battery in their detector .. if they are ganged then that may be an apartment management maintenance item ..
Sep 19, 2009 | Kitchen Appliances - Others
Phone is chirping
Most phones chirp.
1. Low battery........NEEDS a 12 hour or more charge from phone charger.
2. Loosing signal.
3. Electrical interference.
4. Some set communicate with the base for freqency signaling and change channels automatically when interference occurs. The chirp is to autonotify the user.
Most importantly, think about the situation when chirps occur and write it down. At some later date, compare your notes and you'll find your culprit.
Hope this is helpful.
Feb 24, 2008 | Jwin JT-P33 Phone
First Alert SA302 Dual System Smoke Detector Logo
690 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
