Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub 350 fax doesn't dial out.
We just inherited this machine from another office, no manuals or information. the printer does recieve faxes, but when trying to fax out get message "the following document has not been transmitted, try to retransmit the rest of the pages" We have had the phone line checked and you can dial out both ways.
  • Tim Babcock
    Tim Babcock May 11, 2010
    There should be two phone jacks on the copier. It should be plugged into the line jack.
    Is this the case?
3 Suggested Answers
Kevin Hayes
  • 167 Answers
SOURCE: konika minolta bizhub 350 fax no answer
Try altering the maximum nuber of rings until it relays the no answer message.
I am not sure exactly where that is.
ALso, you could try turing on the phone line volume so you can listen to what is heppening.
Posted on Sep 22, 2008
SOURCE: BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Posted on Jan 16, 2009
  • 468 Answers
SOURCE: bizhub 350 windows 7
After you connect printer in network just set up DHCP in your printer and from windows 7 (Devices and Printers, Add new networked printer) and job is done because windows 7 will recognize printer and install appropriate drivers.
If you have problem with that uou can set up Static IP Adress in printer and search by that IP, also you can download drivers and software for that printer from this link:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=867
Posted on Feb 10, 2012
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
Printer : HP Office jet 4355 All-in-one cannot receive faxes
Your Machine Seems to be in "Telephone" Mode, which do not automatically recieve faxes. Please refer your manual and switch it to "Fax" or "FaxTel" mode. It will recieve faxes automatically then.
Aug 03, 2010 | HP Officejet 4355 All-In-One InkJet...
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Konica Minolta bizhub 200 Printer
Trying the set up the fax operation for the bizhub C250. I am unable to send or recieve faxes.
I need to know what you did to set it up.The set up goes like this,
1) install card
2) go into service mode
3) touch system 2===option board status===fax (main)===end
4) touch system 1===marketing area===fax target==US=push end twice
5) touch initialization==fax function and communication==yes=yes
6) turn off and on
push the off hook to see if you get a dial tone. If you don't get one check the phone line
Dec 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Optional Fax Kit FK-503 Installation
yes there is a manual, but it required certified technician by konica to install this for you or authorized dealer.
Jun 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
4. Touch Admin2
8. Touch Gateway TX
Dec 23, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konika minolta bizhub 350 fax no answer
Sep 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Fax function doesn't work
check your phone lines.then connect it to the machine.press on hook dial.if dial tone is not there you may need a service engineer.
Apr 05, 2007 | Ricoh Aficio 2018D All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
175 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
