Question about Whirlpool LEQ9858P Electric Dryer
Dryer only gets hot when empty
We just put new thermastat in please help
  • 641 Answers
There is a high temperature limit switch in the exhaust duct. It may be opening up on you at lower temp. than it should. You could also have lint buildup in the duct causing it to open up at lower temp. First check the duct and make sure it does not have buildup in it. Then locate the Hi Temp limit sw. and replace it.
Posted on Mar 13, 2009
Dryer gets hot then trurns off ,let cool down ,can start again ,but.. will run,or get hot turn off again...is it the the thermastat ?
I think you're on the right track. Thermostats aren't expensive or hard to change on most dryers.
Oct 11, 2014 | Dryers
Over heating
why you put new pump,I would put new radiator first.
Mar 14, 2013 | Cars & Trucks
Car running hot
You could try to change or empty the catalyst, if it's old and never changed, this could be the problem, as the exhaust won't let through easily enough. If i were you, i would empty it at first to make sure this is the problem, as well as getting about 15 horsepower more, probably more if the catalyst is very old. easiest way to empty it (at least with some other cars, i don't know about Pontiac) would be to take it off and use a crowbar to smash it up inside, and pour it out (yeah, i know it sounds suspicious, but it works)
Aug 12, 2012 | 2004 Pontiac Grand Prix
HOW TO CHANGE THERMOSTAT ON THE V-6
First make sure engine is cool.
-Put drain pan under car, coolant will run out.
-Remove the TOP radiator hose that runs to the metal thermastat housing. Coolant will now be running out, try and direct it to the drain pan below.
-Remove the thermastat housing, BEFORE removing the thermastat make sure you TAKE NOTE at how it is situated in the casting.
- Take the thermastat housing and run a wire brush on the flat spot were the old gasket material is.
-Both mating sides of the thermastat housing MUST BE PERFECTLY CLEAN. There can not be any old gasket material left.
-Insatll new thermastat.
-Put a very light amount of PERMATEX orange high temp. silicone on BOTH sides of the new gasket.
-Put a small amount on bolt threads also.
-Now install thermastat housing, and bolts.
-Tighten bolts down a little at a time, alternating between the two, unitl till they are tight.
-Install the radiator hose, and tighten hose clamp.
-Remove radiator cap, pour in coolant, until it sits just below the radiator cap neck. This may take a little time as the system has some air in it.
-Install the radiator cap. Make sure you radiator overflow tank is filled properly.
-Remove the drain pan, make SURE ALL the tools use used are secure, and out of the engine bay.
-Start engine, and place your heater control to 'HEAT"
-Let engine run until the top radiator hose is hot, which means you thermastat has opened.
-Keep watching the engine temp AT ALL TIMES, we wnat to make sure there is no air in the system.
-Inspect for any leaks. Now when the top radiator hose is hot make sure the hose clamp is tight.
Please let me know how it goes.
Feb 11, 2010 | 1993 Buick Skylark
Electric Dryer run too hot
wow, dont get burned, check your ventillation, make sure your vent is not clogged or smashed, if this continues, then change out your thermastat
Aug 16, 2009 | Frigidaire FDE647RF Dryer
1995 toyota 4runner gets hot with new thermastat gasket
the thermostat should be closed when you take it out, therefore the thermostat is bad. It does not closed.
May 22, 2009 | 1995 Toyota 4Runner
Temp gauge and light come on and dies
you may need to change your heater core to allow the water to circulate better,,,it sounds like it may be partially clogged
Jan 13, 2009 | 1999 Plymouth Breeze
Dryer not getting hot
if you not technicail dont try,,,unit needs to be plug in for some tests...warning,,to start im thinking unit runs but dont heat..chech your operating thermastat first ,,next check yiur hi limit thermestat..they should be closed,,if good check your ignitor there should be 110 present..
Dec 26, 2008 | Kenmore 63942 Dryer
Dryer to hot
the element is grounded to the element housing need new element and thermastat kit
Apr 08, 2008 | Whirlpool LEQ9858P Electric Dryer
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Whirlpool LEQ9858P Electric Dryer Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
