Klash drive will not fill - Computers & Internet
    Problem Solver:
  • 17 Answers
What is a klash drive? Are you thinking of, as Smithbrother asks, a flash drive or thumb drive?
If you are, most don't hold exactly the amount they say are. For example, a 1 gigabyte flash drive will hold somewhere around 950 or 965 megabytes, a little less than the drive is listed as. That's common. If you're using a small flash drive (and that's what you're referring to), a 1 or 2 gigabyte flash drive costs as little as $12 to $16 dollars, sometimes half that price. If you're using a small size drive, consider getting a larger one.
Let me know if this answers your question.
XMinusOne@gmail.com
Posted on Dec 10, 2008
Check fuel fill inlet
If the check fuel fill inlet lamp or CHECK FUEL FILL INLET message
comes on, the fuel fill inlet may not have properly closed. The inlet may
have stuck open or debris may be preventing the inlet from fully closing.
At the next opportunity, safely pull off the road, turn off the engine,
open the fuel filler door and remove any visible debris from the fuel fill
opening. Insert either the fuel fill nozzle or the fuel fill funnel (see
Refilling with a portable fuel container for funnel location) provided
with the vehicle several times to dislodge any debris and/or allow the
inlet to close properly. If this action corrects the problem, the check fuel
fill inlet lamp or CHECK FUEL FILL INLET message may not reset
immediately. It may take several driving cycles for the check fuel fill inlet
lamp or CHECK FUEL FILL INLET message to turn off. A driving cycle
consists of an engine start-up (after four or more hours with the engine
off) followed by city/highway driving. Continuing to drive with the check
fuel fill inlet lamp or CHECK FUEL FILL INLET message on may cause
the service engine soon lamp to turn on as well.
WARNING: The fuel system may be under pressure. If you hear
a hissing sound near the fuel filler door (Easy Fuel "no cap"
fuel system), do not refuel until the sound stops. Otherwise, fuel may
spray out, which could cause serious personal injury.
Jun 22, 2014 | 2010 Ford Fusion 1.25
Change gear oil 1981
Drain is on the bottom of the drive shaft. Fill is on the side of the drive shaft. Fill the shaft drive assembly to the bottom of the threads of the fill hole. Takes about 200-300ml.
Aug 03, 2013 | 1982 Yamaha XJ 650
Transmission slips in drive but not in 2nd. After placing it in 2nd it them drives fine in drive. Fill problem? Solenoid? Shifter?
Take it to a tranmissision shop to have it check out, Before it gets worse, Unless you have money to burn,
Dec 07, 2012 | 2000 Nissan Xterra
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Jan 11, 2012 | Frigidaire GLTF1240A Front Load Washer
Wanting to know...why d drive fills up?
All drives fill up if you keep putting things on it and don't remove them. What are you saving on D drive mainly? How big is the drive?
May 12, 2010 | HP Computers & Internet
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
Fuel smell after the fill-up. Then goes away as you drive. Also, appear to have no vacumm and or venting sound when the gas cap is removed when filling-up.
thats just the tank venting as you are filling and driving off for the first time, nothing to worry about unless the smell continues then it could ither be fuel cap or maybe a perished fuel hose. hope this helped.
May 16, 2009 | 1997 Nissan 240SX
Boss amp turns off sometimes
There must be some bad solder connections in the amp. You will need a soldering iron and some solder. Plus the skill to use them so you do not cause much more damage to the amp. It is very easy to bridge a solder joint to a close by solder joint and cause a short in the circuit and can be very danergous, even cause the amp to catch fire. If you bridge any solder joints and then power the amp on, you may very well destroy the amp beyond being able to repair it by anybody. So if you are not sure of how good you may be able to solder the board, please just take it to a service center and have them check it out for you. If it is just some broken solder connections they should be able to repair it fairly cheap. Most shops charge about $65 for this type of repair, but not all repair shjops are priced the same, so you would need to check it out first.
It is very common, for car audio especially, to get cracked or broken solder joints due to the nature of them. They get bounced around a bit even when installed properly. Every time you hit a bump in the road the amp gets a little jolt.
If your amp had anything else besides the bad connections, it would not play OK after shaking it.
If you need any further help let me know.
Feb 14, 2009 | Boss Klash K780 Car Audio Amplifier
GE washer model WHDSR209
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
Jul 15, 2008 | GE WDSR2080D Top Load Washer
Computers & Internet Logo
David Payne
David Payne
