Question about Microwave Ovens
Microwave casing gets very hot when used
When I use my mwave, the casing is getting hot each time. Today, I used it for about 7 mins and the case was very hot. It took a good while to cool down, even though unplugged. Are you able to help please?
  • William Miller
    William Miller May 11, 2010
    This can be caused when
    the internal cooling fan is not running properly or by a magnetron that is
    failing.
    When I say internal
    cooling fan, I do not mean the hood vent exhaust fan which you can turn
    on and off manually.
    I'm instead talking
    about the internal fan which comes on automatically whenever you
    microwave.
    It is vital that the
    cooling fan runs, or the magnetron will be destroyed.
    Is that fan running properly?
    Any unusual noises? Is
    it louder or quieter than usual?
    Please reply back with your brand and model number so we can help you.
MicrowaveSvc
  • 9086 Answers
SOURCE: khmc107b (not a bt): lost power, won't start again
The most likely causes are an open thermostat on your magnetron or the internal fuse. You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 The fuse is shown on diagram 5 and the thermostat on the magnetron is on diagram 8. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 25, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp Carousel Model R-9H56
Did you happen to spray any cleaner directly onto the keypad? Hope not. Just wanted to exclude that poissibility to save time.
Assuming this model does not have a feature allowing you to turn off the turntable via the control panel, the motor msay be failing. Or you may have a bad door switch.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
  • 17 Answers
SOURCE: microwave gets very hot on
If it gets hot enough were it is uncoftable to lay your hand on it then there is most likely a problem. If it is a new unit I beleive I would return it. Good luck.
Posted on May 17, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: microwave dish/tray rotates intermittently.
If the turntable is not turning, you will get hot spots and uneven heating.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can get Samsung parts here.
Posted on Aug 03, 2008
  • 3600 Answers
SOURCE: my microwave only heat after a long time on the highest hot setti
The microwave emmiter bulb has most likely died.
Posted on Aug 03, 2009
Dometic microwave model dotr12cb runs but does not heat
The most likely cause is the magnetron or the inverter board, if the microwave was manufactured 7 years or less. It is cheaper in most cases to replace the microwave oven.
Jun 13, 2012 | Microwave Ovens
I've repaired my (R1460A, over the range, black) mwave several times, after having new cabinets and ceramic tile installed. I want to purchase a new one that will fit the existing wall mount and...
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Ask them about a "drop-in" replacement.
May 26, 2011 | Sharp R-1460 Microwave Oven
My delonghi em821aan-x2 works without making food hot
in most cases the magnatron has gone bad as they are very expensive in most cases we write them off . sorry i think its time for a new microwave
best wishes
sonic boom electronics
Nov 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
While in use my microwave shut off and stopped working. Could it be a fuse? If it is a fuse where would it be located.
mwaves shut off when they overheat and take a time to recover. This is a failsafe to prevent fire.make sure the unit has plenty of airflow around it and the vents are not blocked off ( hutches are notorious for overheating Mwaves) Sometimes the steam from a potato or a cup of water will overheat the sensor and cause it to shut down.
If it is a fuse the whole outer case hasd to be removed and it's usua;;y top left or right on the inner pod.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | GE Advantium SCA2000B Microwave Oven
WONT START UP AFTER USING FOR 4 MINS OPEN DOOR
The oven is overheating. Ensure that all external vents on all sides are perfectly clear and that there is sufficient clearance around them as specified in the instruction manual. Also ensure that the vents inside the oven cavity are clean and clear from obstruction.
If this does not fix your problem then you probably have a failed cooling fan, this will entail removing the outer casing and testing that all fans work correctly, most microwave ovens have just one but many have two and sometimes three. A failed fan repair will require the use of a multimeter and some general electrical repair competency; if in doubt get it done professionally as some of the voltages beneath the casing of a microwave oven far exceed mains voltage and can kill you.
Labour rates for fan replacement are generally cheap as, like most jobs on any microwave oven, component replacement is usually very quick and easy for a competent person.
I hope that my posting has been of assistance to you, if so then please take a moment to rate my answer.
Jan 11, 2010 | Thermador Microwave Ovens
Microwave randomly just goes out. Have to go to circuit breaker box and flip the breaker. Can then reset the microwave.
Is it just the microwave or are there other things riunning on the same circuit?
Electric jug, dishwasher. TV
If nothing else is on at the same time and the Mwave trips then it time to get a new Mwave. But have an electrician put in an additional circuit to lessen the load on that one circuit. Cost about $70-100 depending on distant of meterbox to the main plug.
please tate our help to keep the srvice online
Aug 20, 2009 | Microwave Ovens
My new (less than 7 months old) JVM1540 microwave just quit. It was working multipLe times earlier today. The main breaker does not show as being 'tripped' and appears to be working. Help..??
Take the microwave back to where you got it, whatever is going on it should still be covered under warranty. it may just be a fuse but a warranty is a warranty. Make sure to take your manual with you just in case they give you any ****. Warranty is located on pg. 15?
Jul 17, 2009 | GE JVM1540DM Microwave Oven
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
My Emerson MW8115FS 1450 Watts
hi your door has hooks which activate switches.one of the switches is called the monitor switch .the purpose of this switch is to close the mwave circuit[complete the circuit] indicating your mwave is safe for use.at present your mwave circuit is open therefore your functions arenot working .check if door hooks are making contact with the switch ,check if the swith is testing continuity.ihope ihave been of assistance let me know cheers
Feb 05, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
241 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
