Question about Sansui LCDVD200 20 in. TV/DVD Combo
When I turn TV the screen divides into 9 screens with heavy interverence
Sansui lcd lct37sd When I turn TV on the screen divides into 9 screens with heavy interverence and I can't get rid of it Please help Thanks Fabienne
0 characters
1 Points
Screen display child lock
Hold down TV/AV & LOCK button together for a while. The TV must get unlocked. OK.
Aug 24, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
No picture will talk, picture dark
If you mean you have nothing on the screen, either the backlight or its associated power supply has faiiled. Look at the screen at several different angles; if you can see some sign of motion, then the LCD panel itself is still ok.
Nov 06, 2008 | Sansui LCDVD200 20 in. TV/DVD Combo
TV does receive broadcast signal
get some rabbit ears..... or a little dish reciever that sits ontop of ur tv til FEB 17th...then u have to have the new converter, which u can get government coupons online ....or ull just get fuzz after that... i use the old cheap rabbit ears antennae and i get 6 channels ....
Oct 25, 2008 | Sansui Combination Televisions
I get a dark square in the middle of the picture after about 1 minute of play on one channel
Press closed caption button on remote repeatedly until nothing about closed captioning come up on the screen.
Aug 25, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Screen or lcd is broken
If your set isn't more than a couple years old, the same part number may be available but . . . typically, with the continuously falling prices of new sets, the cost of the replacement LCD may not be worth your while. Check prices on a current model that matches your features before even bothering to try to find a source for the part.
Jul 04, 2008 | Sansui LCDVD200 20 in. TV/DVD Combo
Black Box On Screen
Salutations Cranberries,
The annoying black box is usually a feature of the closed captioning called "Text" You should be able to go in to onscreen menu and select caption options. Unless you need to have the closed captioning on for medical reasons, it maybe best just to turn off all captioning options.
Hope this helps.
Go Ahead. Use Us.
May 27, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
High pitch buzzing and no picture
Your power supply, I mean the internal power suppy could be faulty, if you know how to deal with it, check it for abnormal oscillation, or get some help from someone who knows how to repair it.
Jan 28, 2008 | Sansui CVDV9000 9 in. TV/DVD Combo
DVD Video Player on Sansui Combo
I am having the same problem. But, some work and some don't. It is very frustrating.
Jan 11, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
When I turn TV O
When i open it screen takes 15-20 minutes to be displayed complete.sound & other things are ok.So i request to have sansui tv service dealer in Mumbai/Navi Mumbai/Thane India No; to contact. Regards M.w.Ahmed
Mar 02, 2007 | Sansui LCDVD200 20 in. TV/DVD Combo
Screen overscan too great
sOUNDS LIKE YOUR OVERSCANNING FOR SOME REASON.. MMM STRANGE AS USUALLY THERES AN UNDERSCAN PROBLEM IN THE VERT WITH THESE SETS.Opps sorry about caps. I would check to see the power supply ic and make sure its not putting out more then its supose to as I remeber those are between 125 and 130 volt dc output. as maybe the High Voltage shutdowns not working.oh is is too long and too wide??? if its only like too tall there is a small opot on the pcb thats for the verticle height buit its so small and easy to break off and if you do that the set will lose the verticle sweep totally. good Luck
Apr 06, 2006 | Sansui CVDV9000 9 in. TV/DVD Combo
Sansui LCDVD200 20 in. TV/DVD Combo Logo
23 people viewed this question
Top Sansui Combination Televisions Experts
matt martin
matt martin
Are you a Sansui Combination Television Expert? Answer questions, earn points and help others
