Question about Nakamichi Audio Players & Recorders
I have a Nakamichi 700 Mk 1 cassette deck. Everything works fine apart from it chews tapes after about 10 minutes of playing. Afer a few minutes of playing, a loop of loose tape is generated between the capstans. This eventually wraps itself around the capstan. I have replaced both the centre belt & capstan belt but its made no difference. I understand that the machine is designed to maintain tension across the heads. This implies that the pulley/flywheel for capstan 'A' (part no. CA-5006) rotates faster than flywheel 'B'. I have measured the diameter of the pulley for both flywheels. Pulley 'A' is 47.20mm diameter and pulley 'B' is 47.00mm diameter. Therefore pulley 'B' will rotate faster than pulley 'A' and a loop of tape is bound to form between the capstans. Where am I going wrong? Can you help? Calum (UK)
  • Man-Pig Dec 11, 2008
    I have tried the switch on & off solution and it makes no difference. Please remember, being a 1974 product there are virually no silicon chips in the Nakamichi 700 cassette deck. Thanks.
    Hi PuerkoNess,
    The motor appears to be fine. There are no funny noises from the mechanism but both flywheels do appear to be running eccentrically by the tiniest amount - flywheel B being the worst. There is no discernable play when trying to wiggle flywheel A from side to side but there is the slightest amount of play between the capstan shaft and bearing on flywheel B. Is this likely to be the problem? If so, are new Capstan Flange Holder Assembies available (part # CA-5160)? Thanks.
    Genius:
  • 1,239 Answers
Hi
This may be a reel sensor problem, or the rotation of one of the reels is stopping for some reason. Most of the time, these faults are mechanical. There can be worn belts, or drive wheels, or gears, and etc. Sometimes there are faults in the electronics where a sensor is not being read properly.
The unit should be properly checked to evaluate the fault.
Posted on Dec 11, 2008
  • 275 Answers
First let me say Hi!! It's very nice to see you on this site Calum, I've seen your work and im a fan.
Now let's talk about your issue. It seems to me that you might have a problem with the motor that controlls the pulleys, it could be either one. Or you might have a loose pulley, again it could be A or B. Try to stare at them in action to see which one it is, and also listen for any strange sounds they might make when rotating.. Good luck!
-PuerKoness!
Posted on Dec 10, 2008
  • 734 Answers
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it
Let me know if this works, if it doesn’t then I’ll provide some other alternative solution.
Thanks
  • futureloginn
    futureloginn Dec 11, 2008
    please go to the following link for service manual ---
    http://stonessoundstudio.com.au/stone/na...
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
Hi NAKAMICHI, I'm looking for a head cassette deck type DR8 where I can get ..thanks NAKAMICHI
Check ebay every few days and this web site - http://mobile.audioproz.com/AP.php?Prod=Cass_Parts&Pg=18&Sort_By=Model&Sort_Order=ASC
Jul 27, 2016 | Nakamichi Audio Players & Recorders
Nakamichi DR 10 does not eject. I loaded a cassette, pressed 'Play' the cassette played 10 seconds and stopped. The display showed 'ERR'. I removed the cover, nothing immediately obvious. The cassette...
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
Sep 19, 2013 | Nakamichi Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Nakamichi BX-125 Cassette Deck
Check leaf switches and also, press play -- after a few minutes, feel motor(s) for heat build up. If it gets hot, either motor is bad of something is preventing it from rotating
Apr 23, 2008 | Audio Players & Recorders
Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Apr 06, 2008 | Audio Players & Recorders
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
