Question about Garden
On my two stage snow blower--main auger stops turning .
I replaced the 3 belts on the machine but the main auger stops when I hit snow higher than a couple of inches. The secondary fan keeps up at top speed.. The machine is an MTD yard machine 8hp probably 15 years old. Any help possible appreciated.
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Posted on Dec 12, 2008
I have a Toro two stage snow thrower that has an auger issue..left just spins as it want the right moves do I fix...the machine is 13 years old can't find any please.
The shaft has shier pins that break when an object gets caught in the auger. This prevents further damage. You will need to replace that pin. Make sure you stop the blower, unplug the spark plug before working on it. The pin holds the auger to the shaft. Turn the auger until you see the hole through the shaft and insert a new shier pin.
Dec 12, 2016 | Garden
Auger does not stay engaged when the lever is released to turn the chute, even though the traction drive is still engaged. Very annoying when trying to clear snow. How can I remedy this? Thanks
Either two things come to mind, first I would check the shear pins. When a shear pin is broken, the auger turns but stops as soon as it hits a load (snow). The shaft is turning, but there's no mechanical connection between the shaft and the auger.
The second thing is the belt either needs adjusting or replaced. Belt adjustments should be checked before every winter and are simple to preform. When checking the drive and auger belts, look for glazed running surfaces, and cracking. Either sign means the belt(s) need replacing. Also if the belt(s) have streched beyond their normal adjustment.
Sep 18, 2016 | Garden
Auger belt burns out
un-seize the auger action
replace rusted bearings
Feb 07, 2016 | Garden
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Auger won't stop
Open up plastic cover over belts.There is a pulley that moves against belt to engage front auger.There is a spring that hold it in the off position and when you pull the handle it moves that pulley.Sounds like spring broke or slipped off.
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Snow thrower auger won't turn
One of the grip levers should engage a clutch that controls the augers. The other grip lever should engage a clutch to drive the wheels. Figure out which is which, and track the linkage from that lever down to the gearbox between the augers and the impeller. See if there's an adjustment you can make there.
If not... the gearbox may be damaged, possibly by hitting a solid object with hardened bolts in the place of your shear pins. ALWAYS use soft shear pins!
Feb 16, 2014 | Craftsman 24" 179cc Dual-Stage Snow Blower...
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Jan 25, 2014 | Simplicity I924E 2-Stage Snowblower...
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Accidently hit stick in side yard. now wont throw snow. Everything else seems good
blower might still work but gear case that runs auger is shot or you sheared the shear pins in auger
Dec 17, 2013 | Yard Machines 31AS63EE700 208cc Gas 24-in...
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
Garden Logo
691 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
