No, the 180 doesn't have a battery backup. What are the symptoms ... does the sewing light come on or is the machine completely dead. Where did you store it ... is there a chance that the damp has got to the electronics inside ... if so it is best not to power it up until you have an authorized bernina engineer look at it and possibly clean the main processor board etc.
check in the manual and see if it's self oiling or not,, some machine parts are soaked in oil from the factory & don't need to be oiled other machines have to be oiled,,if the manual doesn't say then contact elna customer service and ask them. I won't promise the machine will work or won't work if it's been sitting for years ,sometimes the grease can become sticky and hard. you'll be able to tell as soon as you start sewing, make sure you read the manual completely, that way you know what the machine will do and what it won't do. always use the proper needle for the fabric and the proper foot if you go over a seam and the machine seems to struggle, take your foot off the foot pedal and use the handwheel to move the needle manually over the seam, that way you don't bend a needle and cause the machine to jump time. also make sure to have a comfortable chair and good lighting and a good seam ripper just in case of a mistake. if you get frustrated while sewing, get up and walk around, that can help clear your mind, I've had to do that plenty of times and I've been sewing for 30 years. if you don't have a manual send me a comment and I'll try to find you one. there are several websites that have tutorials and other things for a quilter,, happy sewing
is it possible that the needles are in backwards? it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
since the machine has been setting for 20 years, it needs to be serviced the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
if you have a manual check where your feed dog knob is, push the knob in the opposite direction,,if that doesn't help then something may be wrong with the feed dogs,,you should be able to see the feed dogs in the needle plate area & to feel them with your fingers.
you may need to have the machine serviced at a sewing shop
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Thanks for that Rick. I will take it to Bernina.
