Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Can't find the defrost timer to test my fridge CAMCO side by side
I have the 1998 model MRSC20KWXAWH I need to find the defrost timer so I can test the heater to see if it works before ordering a new one. does anyone know were it is? also my ice maker stopped working about a year ago everything looks fine but no ice?
    President:
  • 1,197 Answers
Yes the ice buildup is coz of a problem in the defrost cycle... and u wud be required to test all the three components.....
first we ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
* We have received two reports of cases in which only one pair of terminals shows continuity and when the timer is advanced, the same pair still shows continuity. For these isolated cases, this was reported to be the correct operation of the timer. At this time we have not been able verify this case. This may indicate a specific model or models that use a different wiring configuration than discussed in this article. Also, note that this article applies to mechanical defrost timer controls and not electronic or adaptive defrost controls.
Posted on Aug 30, 2010
  • SAM JAYANTH CHANDRASEKAR
    Before testing the defrost heater, again make sure u unplug the freezer to avoid an electrical shock hazard.
    The defrost heater is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear or bottom inside panel of the freezer.
    The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver.
    There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way.
    The heater is connected by two wires.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
    Test the heating element for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading somewhere between zero and infinity. If the reading is not between those two extremes the heating element should be replaced.
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Apr 22, 2012 | Frigidaire Refrigerators
Kenmore fridge leaks water on floor and then stops cooling. Tech said it needed heater/defroster and would cost $500. Does this sound right.
Ah no. If the fridge was not defrosting then water would not be leaking out.
It sounds like the defrost timer is not completing it's cycle. You may need a new defrost timer.
The cost of a new timer, call out, fitting and testing could be around $375
Mar 31, 2011 | Kenmore Side by Side Refrigerator
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Where is defrost timer located
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Jan 14, 2011 | GE GSS25JFM Side by Side Refrigerator
Fridge not cooling,frost on back of freezer its a side by side
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Mar 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator cooling issue
If it's not a defrost problem then it will be a freon/compressor problem which has a 5 year warranty.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} DEFROST PROBLEM
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Jan 01, 2010 | LG LRSC21934 Side by Side Refrigerator
Fridge not cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
OR
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
Oct 02, 2009 | Refrigerators
There is ice forming in the fridge part of the side by side refridgerator. The fridge is making noise, like a motor. it stops once you open the fridge though. Any ideas?
Ice may also be forming in the freezer.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 30, 2009 | Samsung RS2556 Side by Side Refrigerator
Hello I have a gallery series refrigerator about 15 years old that is not cooling enough. The freezer is acting like a fridge and the fridge is useless. Any suggestions? Thank You
Sep 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
151 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
