Question about Measuring Tools & Sensors
The motor seems to be loosing power when ripping stock!
I've had this table saw for 5 years now it's a great saw. I'ts a Delta 5 h/p left tilt. I bought it just before the x-5's came out. Anyway I'm a wood worker not a mechanic. With that being said the motor for some reason almost comes to a halt while cutting. This has never been a problem before just barely started. I tightened down the motor to take any slack out of the belts but they seemed pretty snug in the first place. There is no weird sound when I turn the saw on however it takes a half second to build it's max speed and then it's fine until I go to rip material then it seems to bind down. It will still cut I just have to go slow or else it slows way down, again this is a 5 h/p I've had no problems before. Anyway I'm in the middle of a huge custom project I hope you guys can help me .
Thanks for your time
Jesse S. Neville
''Interior Structures''
It's an AC induction motor, right?  Is there a "run" capacitor?  Have you checked it?
(With the saw disconnected from AC mains, short out the capacitor to ensure that there is no residual charge. Disconnect one of the leads to the capacitor, effectively taking it out of the circuit.  With your ohmmeter on someting like a ' X100" scale, connect the leads to the capacitor terminals; Does the needle fly to "0" then slowly climb toward something like 2-5-10 megohms, or thereabouts?  Now remove the leads, short the capacitor and reverse the ohmmeter leads when you reconnect the ohmmeter.  'Should fly to "0" and climb as with the previous test.
If there isn't a significant phase difference between voltage and current, the motor will lack power; that's what the "run" capacitor is for.  They can go bad.
Hope you're not.... er...  uh....  "In-capacitated" .
Posted on Apr 21, 2009
  • 118 Answers
How are you plugging the saw in? It sounds like the saw is not getting enough voltage. Be sure to have it on a 20A circuit without any extension cords...
Posted on Dec 29, 2008
I have a delta 34-444 table saw, is it a right or left tilt, or how do i find out?
Left-tilt, right-tilt refers to the direction the top of the blade can be tilted when it is not straight up and down. There will be an indicator on the front of the saw, normally pointing to zero. When you adjust the blade away from zero, if it tilts to the left, it is a left-tilt saw.
Feb 05, 2013 | Delta Machinery Delta 34-555 Sliding Table...
Changing volage on table saw
usually on the back of the plate where the wires go into the motor there is a wiring diagram for changing the voltage. UNPLUG saw first before removing the plate. Let me know if you need more assistance and I will try and help
Dec 30, 2011 | Delta Machinery 10" Left Tilt Contractor'S...
When I flip the switch it foes not run. I used the saw for several cuts, I tried to rip another pirce and it just wold ot run. Tried the rset button and it seems like it is stuck. Wwiriing is all...
Sometimes switch gets dust inside the "sealed" switch. Had 50/50 luck taking apart and blowing out. Can test it after switch is out to see if it is faulty by jumping wires.
Aug 26, 2011 | Delta Machinery 10" Left Tilt Contractor'S...
I have a Delta 36-979 table saw. In a recent move, it seems I lost the drive belt when I took the motor off for ease of moving. Can I get a replacement at a local auto parts store or do I need to order...
I can't find any specs for this belt, You can buy it online from them the part number is 643928 and the cost is around 7.22, Sorry but this is the only information I can find for you.
Apr 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
My table saw will not start. the power source is good.
If the motor is using a single phase supply there will be a capacitor which could have reduced in value- open.
If so try and use a capacitor in parallel to see if the motor works-- in this case the motor might hum and get heated up.
Mar 11, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot.
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Measuring Tools & Sensors Logo
205 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
