Question about Indesit W 123 Front Load Washer
Drum filling up
Drum keeps filling up with cold water/cycle will not advance.I have replaced heating element but has not solved problem.
    Problem Solver:
  • 16 Answers
Could be anything, Programmer, Pressure switch, etc.. Depending on age of machine. If more than a few years old I would check to see if the pressure switch tube, or reservoir, is blocked with powder or gunge. Tom.
Posted on Mar 09, 2007
Washeing machine not heating up
It sounds like either the cable's have rusted off, fallen off the water heater element. Or the Water heater element has failed.
Watch this link to get the repairs done
How to replace washing machine element on Hotpoint washer
Mar 04, 2014 | Hotpoint Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
Sep 13, 2013 | Roper Washing Machines
Hotpoint WDL520P Washer dryer Filling up with water as it should during the drying phase untill the end of the cycle when it fills up entire drum with water constantly during this cycle it is constant
The other logical point is that it can be related to a faulty output or error from the program controller output. In some cases choosing an alternate program cycle can confirm this case of faulty cycle patterns.
Feb 12, 2013 | Washing Machines
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Oct 10, 2010 | Dishwashers
It keeps getting stuck on rinse cycle a
Check it out....
Good Luck!!
thanks
Jul 19, 2009 | Fisher and Paykel Washing Machines
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
122 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
