Question about Saws
Have a sear's table saw. It quit running while cutting a piece of wood. It tripped the main breaker at the electrical panel. Reset breaker saw would not start. pushed reset button on motor saw still will not start. Any suggestions
  • 22 Answers
Some times you have to turn breaker off and back on. how many amps is the breaker. is the saw 110 or 220 volt.
Posted on Dec 13, 2008
Circuit breaker trips out
What is the rating of the breaker? Is this enough to run the saw? If this is ok, has the motor become damaged or has the blade got dirt or wood dust slowing it down?
Jul 25, 2014 | Hitachi C10FR 10" Job-Site Table Saw 15...
Quit running when I turn the switch on nothing
1- You likely overheated the motor find the small red button on the end of the motor and push it after the motor cools down some
2- You tripped a circuit breaker in the electric panel, go to the panel and look for the breaker that does not line up with the rest of them and move it off then back on.
3- If your outlet has a GFI on it go reset the GFI reset button.
Nov 07, 2013 | Delta Saws
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
What can be done with a scoll saw, table legs?, what uses is the scroll saw for
Scroll saws use a small thin blade that runs up and down very fast. It is used to cut curved designs out of flat wood. Table legs are made on a lathe, it spins a square or round piece of wood to make legs, baseball bats.
Mar 01, 2011 | Garden
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
Wood feels like its "pinching" between blad and fence
Possibly the problem is the wood itself. If it is burning both sides of the kerf then it is probably that your kiln dried wood is picking up moisture on the outside from the environment which causes it to bow inwards as it passes the saw. I have even had this problem with plywood. Just keeping timber in an unheated workshop for a while can cause the problem but after a few months it should equalize and the problem disappear at about 15% moisture content. (kiln dried timber should be nearer 10%)
Cut part way along a plank and then mesure the kerf at the end of the plank and at the front of the cut. if it is significantly narrower at the plank end then that is your problem.
These hard woods you mention are always a problem to cut on domestic saws at usually a maximum of 2000 watts . I use a 4500 watt motor in my saw and it will still complain at dry oak, ash and maple etc. especially if they are moving a bit as I cut them. Before I retired I had a panel saw half as powerful again as that and still those hard woods could cause trouble.
Jun 01, 2010 | Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Table saw smokes.
Sears will refund you. Take it back!
Mar 28, 2010 | Saws
Does not turn on. The wood was at an angle and jammed when it quit working
Hello. I recommend that you check your circuit breaker or fuse which is in the house panel and feeds the outlet that your saw is plugged into.
I believe that you will find that you solution is to reset the breaker or change the fuse.
Nov 28, 2009 | Craftsman 10" Table Saw
Delta Radial arm saw 33-990 tripping circuit breaker
More than likely motor but try this , if you have a wrap around amp probe or can borrow one or purchase a cheap one place the amp probe around the positive wire connected to panel breaker ,with meter on proper scale ,start saw and read probe current , if cap bad current will be high and stay until breaker trips , if motor will start high on start ,then low then ,very high and breaker will trip , be careful in panel working around live circuits , the reason it reads this way is because as the motor warms the laminates it the armature separate and cause the increase in current to spike ,if cap bad never gets to speed and has high current draw constantly , to verify cap(1) remove from circuit (2)place a screw driver across terminals to release any charge (3), then take ohm meter on ohms place meter leads on terminals one on each terminal at same time meter will rise and fall back(4) reverse leads and should rise and fall as before if it does this it is more than likely good a lot of electrical reasons for this but this will tell you what you wanted to know , good luck
Dec 08, 2008 | Saws
Saws Logo
243 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
