Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
CD loads properly but turntable turns a couple times then stops.
Turntable turns breifly then stops and tries again. After about 30 seconds of off and on spinning (never any sound) it will return the CD to the carousel. Occasionally it will actually play a selection but can't be counted on. This is a Wurlitzer 1015 100 CD capacity. Thank you--- Mike
    Problem Solver:
  • 5 Answers
Had this same problem with my 1015; spoke with "Doctor Jukebox" from Folsom, CA about it. You can find him on craigslist.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Posted on May 22, 2010
  • 734 Answers
These sets are very common for defective spindle motors as we usually just replace them and that corrects the problem. But sometimes it doesnt fix it and it turns out to be a defective laser assy as any cd or dvd player/recorder must focus on the disc before a spindle will spin. Oh one more possible problem could also be the turntable could have gotten pushed down and wont let the lens focus.
Thanks
Posted on Dec 10, 2008
  • 586 Answers
    According to the symptoms it shows that the problem is in two sections,
1- tay mechanicaly unstable.
2- The lens needs to be replaced.
Therefore, First change the optical lens assymbly with the same part number,And adjust the mechanical of tray.
Thanks for using fixya.
    Genius:
  • 1,550 Answers
The possible causes
  • Dirty lens. You need to clean the lens using lens cleaner
  • Cracks in ribbon cable to optical pickup
    Sergeant:
  • 399 Answers
The lens is weak.or did u changed the setting
  • 275 Answers
Problem looks like the laser might not be reading the cd's so that's why it returns it. Might want to get a Lens cleaner .. that should help it read your CD's . What do you think of this ?
How do I remove the white plastic turntable plate that moves the wheeled legs of the turntable??
inside the cabinet, there is (usually) a belt that turns that gear, you will have to unplug the unit and take off the cover to get at it, probably has some grit in the belt or such, also look for missing teeth
Jan 12, 2015 | Microwave Ovens
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE HAS STOPED TURNING, ANY ADVICE MANY THANKS. TONY Nr IRRLAND
Two possibilities: either the turntable coupling is broken or the turntable motor has quit. The plastic coupling can wear or crack so it no longer fits properly on the turntable motor shaft. Then even though the motor still turns, the turntable doesn't. Or the motor itself may have stopped working. If the plastic coupling still looks normal and you can't rotate it easily by hand while it's in place, it's probably the motor.
I'm here in the US so I can't suggest where to find parts, but you should be able to locate a supplier who might have replacements available. Of course the oven will still work without the turntable running. You'll have to open the oven occasionally and turn the food yourself to insure even cooking.
Jun 03, 2009 | Whirlpool MH7140XF Microwave Oven
Turntable is wacky
try loading half your discs on one side of the turntable and the other half on the other side and see if that solves it.
Jan 18, 2008 | Sony MegaStorage CDP-CX355 300-Disc CD...
Axis 9
i have exactly the same problem, its annoying
1 thing which works is holding the button down then spinning the deck round, let go, turn off the scratch button, press play and turn on the scratch button again
Jan 15, 2008 | Nu Mark AXIS 9
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
