SOURCE: Biostar GF 7100-M7 windows xp trouble
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
SOURCE: driver de motherboard biostar 945Gc-M7 TE
hello, please follow the link below to download drivers for your motherboard. This link provides you with drivers/Bios firmware/manual/CPU support and memory supprt information.
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=303
I hope this helps, let us know if you need any further assistance.
Good luck,
Kind regards,
Amar Sondhi
SOURCE: THE BIOSTAR G31-M7 TE MOTHERBOARD WONT START UP
Good day sir, hi. you need these 7 things to make your pc start, make sure they are good.
first unplug your pc. open the side panel to access the motherboard. Remove all connections to the motherboard.
Power on your PC.
monitor your PC speaker.
You should hear a beep, (good) one long and 2 or 3 short beeps, problem with the display card, continuous beeps, system board cannot detect memory.
monitor your keyboard.
You should see 3 sets of led light, numlock+caps lock+scroll lock, and a few seconds, 1 led light, the num lock only.
SOURCE: No audio from Biostar g31-m7 te motherboard
check bios setting and v erify that audio codec(AZALIA) is turned on
