Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
WFW8300SW01 rear bearing noisy
I have a WFW8300SW01 for 18 months and during the spin cycle the washer is VERY noisy. The ball bearing sounds like the grease is missing. (metal on metal)  I have had an authorized service call and the tech said the rear bearing is out. He called back a week later and said he could not figure out what part / assembly to order.  Whirlpool said they would supply the part but I had to pay the labor cost.  I’m willing to take on the project but how do I find the part number to order from Whirlpool?
Any suggestions are most welcome.
  • Anonymous Jan 29, 2009
    I have the same issue and wanted to see if the issue was resolved by the first writer.....
  • Anonymous Mar 13, 2009
    I have been in Florida for the winter and will be back to work on the washer in April. I'll keep you posted.
    Goodmail
  • 107 Answers
You need a "tub job". New rear tub with bearing and possibly a basket..This is caused by the wrong or too much soap or constant overloading. It takes 2 men about and hour to accomplish. I'm a repair tech and this is common on front loaders.
Posted on Mar 13, 2009
  • 367 Answers
Go to sear.com and then to the parts section. Type in your model # and there will be a list of sub compenents to the parts. Click on the tub section and the bearing (rear tub assembly) will be there.
Posted on Dec 10, 2008
  • camskid Jul 07, 2011
    We only had our washer for about 5 years and it is already shot! Just had a repairman out and there were a multitude of problems including door seal, bearings, pump assembly. The cost to repair was outrageous so we ended up having to buy a new one. I think it's ridiculous that a washer only lasts 5 years. The matching dryer also has issues in that the heating coil is going bad. I would never recommend this product.
Noisy spin cycle
IT SOUND LIKE YOUR REAR BEARING IT GOING OUT ON THE WASHER
Nov 02, 2012 | Kenmore Washing Machines
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
NOISE DURING SPIN CYCLE
You have to take the tub out, take off the rotor from the bottom of the washer, remove 4 bolts and take off the stator, take off the bearing retaining nut, then drive the 2 bearings out with a drift. I bought the bearings online for 20 bucks from a supplier (VBX). They are standard metric bearings number 6005 and 6006. I put some silicone grease on the shaft seal and drove the new bearings into place. Then reassembled, and the washer is whisper quiet.
Jul 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Very Noisy Washer!
Hello julierealtor how old is the washer? Try turning the inner drum by hand and see if it is noisey or moves up and down. If so then it is either your rear support of the inner drum that has failed or the rear bearings. If it seems fine, maybe you have something in the drain pump (which runs prior to and during the spin) that is causing the noise. If it is noisy during the drain, then you may either need to clean out the pump or replace it. Hope this helps.
Aug 10, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
432 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
