Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave - 5 yrs old..started to make loud sound when the turntable was on..been using it like that for the past 3 years by shutting off the turntable..Yesterday it stopped working completely. Light is on, turntable does not come on, and neither does it heat..no sound whatsoever. Does this mean its dead?
  • indutolia Dec 15, 2008
    Thank you very much for your advice!!!!
  • GE Master
  • 9,098 Answers
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 13, 2008
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It made a loud noise and was starting to smoke.
Sounds like the magnitron is shot, I wouldn't attempt to use it anymore. When a magnitron goes bad it actually gets much stronger than the unit is made to handle.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped working
to indutolia
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
yes anything can be fixed but a do it yourselfer i reccomend against this cause thats a radiated element in the micro
recommend go out and purchase a replacement go with G.E. they have the 7 year warranty great little micro. too change out is easy
Jun 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Loud sounds, but still works?
Well, it's tough to say more surely without hearing it, etc.
I'd say to use it (and always stay close to it when you do) until and unless some other symptoms occur.
And this is not a cop out - sometimes watchful waiting is called for.
It's always recommended that you never leave a running microwave unattended, but in this case even more so.
Be especially aware if either of the fans quits or if any odd smells occur.
Apr 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
62 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
