Question about Brother MFC 8500 All-In-One Laser Printer
Brother MFC8500 not responding
The printer used to work, but now I cannot print through neither the USB port nor the parallel port on my Brother MFC-8500. Has this printer given up the ghost?
    Guru:
  • 1,049 Answers
Ack, double negative. Bad English...
I've had this same issue. It seems to start happening when the device enters sleep mode, it's like the printer just vanishes. When you remove the printer completely and reinstall it it works again until the printer goes into sleep mode then it disappears again. I've had two do this and once they start I haven't found any way to stop it from happening periodically and with ever increasing frequency until we finally get rid of them. Suspect some level of i/o controller or board failure.
Posted on Dec 10, 2008
My Printer is not printing although the printer status is online. How do I fix it?
If you tell it to print and the item goes into your Que for printing. In that screen click on the printer tab... In the drop down verify that the "Use Printer OffLine" does NOT have a check mark next to it.
Dec 30, 2013 | Zebra LP 2844 Thermal Printer
Don't know how to connect HL-2040 printer to laptop.
If the printer does not have a USB port and the computer does not have a parallel port then you will need to get a USB to Parallel print adapter. One end is USB to plug into the computer and the other end has a standard parallel port to plug into the printer. Install instructions will come with the adapter. Try any computer shop such as Best Buy, Radio Shack, etc etc.
Apr 24, 2011 | Brother HL-2040 Laser Printer
Keep getting the error message "Printer not responding".
How are you connecting the printer to the computer? (USB, parallel, ethernet) Make sure there are no error messages/lights blinking and that the unit is on.
If you are using an USB cable, try a new cable. Also try a direct connection if you have a USB hub or print server in use. Make sure the USB ports are active (not disabled for power saving or security). Test the port with a known working device.
If you are using the parallel cable, make sure it is properly secured. Also try a new cable. Again try a direct connection instead of a print server.
If you are using an ethernet connection, again try a new cable. Check if your firewall is blocking communication with the printer. (Test this by temporarily turning off the firewall. If it starts working, make the printer a trusted part of the network. With some firewalls, you may need to unblock communication for both incoming and outgoing communication with the printer.)
I hope this helps.
Oct 18, 2010 | Konica Minolta Magicolor 5450 Printer
Product scans but then I can't find the result
The first thing I recommend you try is a new data cable. Scanners require bi-directional communication and will fail even when the printer works. Similarly go for a direct connection instead of using a print server or USB hub. (I have a scanner that had the same problem - the preview scan started but no image saved due to a bad cable.) If you are using a parallel port connection, make sure that bi-directional communication is set for the port (in the BIOS). If you use a USB to parallel port adapter, make sure it is a bi-directional (for scanner) adapter.
I hope this helps.
Jul 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
HP1100
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
Jan 15, 2008 | D-Link DP-G321 Print Server
Brother 2700CN Color Laserwriter--Loss of Ethernet Connection
No lights on network card mean that you will need to replace network port/card on printer if cable and connection is sound
Nov 28, 2007 | Office Equipment & Supplies
Error Printing to LPTUSB1 for the printer Brother Hl-1230 series
Connect the device to a different usb port. Download the newest software/drivers from the Belkin web site. Remove the old software and install the newest downloaded version. Please supply the error.
Apr 09, 2007 | Belkin USB Parallel Printer Adapter...
Brother MFC 8500 All-In-One Laser Printer Logo
305 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
