Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Is My TV ATSC or NTSC?
I have a Phillips TV Model number PC9227-C121 that was manufactured Nov 2001 - d I need a conversion box when they change over in February from Analog to Digital or is this a digital receiver?
    President:
  • 2,992 Answers
Yes, you will need a converter box if you are currently getting TV off-the-air with a rooftop or indoor antenna. This TV does not have a digital tuner. You don't need a box if this set is being used on a cable or satellite system (unless your service provider tells you otherwise).
Posted on Dec 11, 2008
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
Dec 26, 2015 | RCA Televison & Video
How do I get free local TV over-the-air stations?
The Quasar VV-2002 only has an NTSC (analog tuner). Very few stations with NTSC transmitters are still broadcasting. Only low-power stations were allowed to continue broadcasting an analog signal. Unless you are very close to one of the transmitters, your TV will not tune in the station.
You'll need to connect the TV to a digital-to-analog over the air converter box. (The low-end ones that were free or cheap with the government coupon are harder to find; a few models are still available.) These convert the ATSC (digital) signal to NTSC. Then use an appropriate antenna and follow the instructions to tune in the available OTA signals. Send these to the TV either on the RF or composite Line-in. Set the TV to the appropriate input and use the converter box to change channels.
I hope this helps.
(20" TVs weren't required to have an ATSC tuner until 2007. Since there are reviews for the VV-2002 from 2004, it obviously is an older set.)
Nov 19, 2015 | Quasar VV-2002 20 in. TV/VCR Combo
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
Why can't I tune in new channels from set top box through vcr?
Sounds like you are trying to receive the new Over The Air OTA, digital ATSC signals on a VCR that can only receive analog NTSC, which are not sent by any but low-power channels. Did you miss the change over last April, postponed from Feb, and featured on every TV channel when you could have obtained 1 or 2 $40 coupons toward ATSC-to-NTSC converter boxes. Try www.dtv.gov for more info, IIRC.
If you are speaking of cable TV then see your company. These may be digital Quadrature Amplitude Modulation QAM signals that only certain TVs can decode provided they are not encrypted. Locals are never encrypted. This is separate from the ATSC conversion.
-Ken
Oct 04, 2009 | Quasar VHQ940 VHS VCR
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
Tv Tuners
Hey jp62388,
According to information provided by the manufacturer, this model TV should have a built-in NTSC/ATSC and QAM tuner. These should allow you to receive locally broadcast digital TV signals without the use of a set-top box or digital converter box.
If you're concerned about your TV's specifications, the most important thing you'll need to look for is a built-in or integrated ATSC tuner. NTSC is the old analog standard that is to be phased out in early 2009, while ATSC is the new digital standard that is to be used within the United States and Canada as NTSC’s replacement.
Should you have any other questions or concerns, I'd strongly suggest checking out the FAQ section of the federal government’s official DTV transition website:
http://www.dtv.gov/index.html
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | Televison & Video
My phillips tv model#27pt5445/37 serial#ya1a0540045497.my question is will i need a converter box for this i have a roof aerial.i donot have cable.
I have this same t.v. According to the product brochure it has NTSC connections, not ATSC. According to the government's DTV website, t.v.s that don't have ATSC connections need a converter box.
So, yes, your t.v., and mine, need digital t.v. converter boxes.
Apr 01, 2008 | Televison & Video
Digital signal conversion
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on epinions.com, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Feb 23, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
218 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
