Question about Acer Aspire 5100 Notebook
I have an acer 5100 and I need to know how to adjust the brightness of the screen. It is really dim. how do I brighten it up some?
  • 395 Answers
Hold down the FN key thats to the left of the space bar and use the up and down arrows to the right of the space bar to raise and lower brightness
Posted on Dec 10, 2008
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
How to brighten screen on acer computer
Press and hold the blue 'fn' key and press and release the left/right arrow keys to dim/brighten the screen. It it the arrow keys on most Acer laptops that control this. If it's not the arrow keys, then look for keys with a picture of the sun on them. Press and hold the 'fn' key and then tap the 'sun' keys to adjust brightness. Please let me know if this helps or not.
Joe
Apr 09, 2012 | Computers & Internet
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
How do you brighten the screen on an acer aspire 5100
Hold down the FN key whilst pressing one of the F1-F10 keys usualy a symbol with a sun and an arrow pointing up for increasing brightness and sun and arrow down for decreasing brightness but remember to hold down the FN key (usualy botton left of keyboard in blue)
Hope this helps
Apr 19, 2010 | Acer Aspire 5100 Notebook
MY ACER MONITOR IS DIM , HOW DO I BRIGHTEN IT UP?
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Nov 27, 2009 | Acer AL1916W 19" LCD Monitor
Screen brightness
You have a "FN" key in the lower left section of your keyboard. There should also be other keys with ink the same color as the FN. Look for one that has a sun and upward pointing arrow. Press both and your screen will get brighter.
If that does not work then your video inverter is starting to go bad and will have to be replaced.
Dec 10, 2008 | Acer Aspire 5100 Notebook
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
Acer Aspire 5100 Notebook Logo
195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
