Question about Zanussi ZHQ575 Electric Double Oven
Keep having to replace element
I have had to replace the circular element in my double oven 3 times in 7 years - what could be causing the problem?
Thanks,
  • Zanussi Master
  • 3,463 Answers
Not neccesscarily a problem with oven, as it is quite a common fault with fan ovens.
You could make sure that the fan is running properly, and is free to turn, and that the fan blades are not covered in grease etc',
Make sure that oven door seal is o/k, as hot air escaping here will lead to longer running times.
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
I have a ZDF20X double oven and the main bottom oven is not heating, The fan and light are working but it is not heating. HOw do I repair this - is it an element and how do i replace ? Thanks v much.
Most likely it is a faulty oven heating element.
You will need to replace the element.
Usually the element is a circular shape which is situated near the fan, normally you will need to remove the back of the oven, Switch off the power at the wall first, locate the element and remove the fixing screws and electrical connections then fit the new element and reconnect.
Only attempt this replacement if you are confident to do so and have a basic electrical and mechanical knowledge.
Dec 11, 2010 | Zanussi ZDF490 Electric Double Oven
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
How do I replace the heating element in Neff U1461N2 main oven?
Switch power off first.
Remove the screws that secure the rear cover in the oven compartment.
There you will see the circular element, undo screws that secure element, slówly withdraw element towards you, disconnect leads, taking care not to lose them behind the aperture., fit leads onto new element, and refit element.
Refit cover and test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff U1721 Double circotherm Electric Oven
Fisher & Pak\ykel element connection
white or red are phase, black or blue neutral
Mar 25, 2017 | Fisher and Paykel AeroTech Double OD302...
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
May 22, 2008 | Neff U1721 Double circotherm Electric Oven
Main oven not heating up
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
Mar 29, 2007 | Electrolux EOU5330X Ultrafan Electric...
Zanussi ZHQ575 Electric Double Oven Logo
197 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
