Question about Kenmore 53582 / 53584 Side by Side Refrigerator
Ice maker repair and still no ice
My fairly new (15 months old) pricey Kenmore Elite side by side icemaker is not making ice. Sears Home Repair was out...tech said the "motor" was bad and replaced it for $250. He said "you'll have ice in 2 hours" and of course more than 24 hours later, it still has not produced any ice. The water dispenser works fine and am not convinced that the motor was bad since the result is still the same. Any suggestions as they're scheduled to return again tomorrow?
  • Amy Close Mar 02, 2007
    Thanks for replying. I did check the optics and they check out o.k. We've also had the frozen feeding tube before this and that doesn't seem to be the problem either. Any other suggestions?
  • willh3 Aug 03, 2008
    I have a Kenmore side by side model 106.55242400. The water dispenser work fine. Ice maker not getting any water. I ran the unit without the filter for a short time until I replaced it. The clear water tube going up to the Ice maker
    in the back has water going half way up, The water in the tube is not a flow getting to the ice maker. the frig is 3 years old. Thanks for your help.
    President:
  • 878 Answers
Amyc, of course you should call this cat back, but here are a few things to check. Make sure that the fill tube is not frozen over. The black tube feeding water to the IM. Next with the freezer door open your optics should flash twice with a pause repeatedly. Hold the left side emitter flap down and the light should be on steady. If this checks, the optics are good. The ice maker rakes should be at the 2:00 position when it's in it's home positon. Any other position could be a bad module. When the cat comes back to check it out, make sure he jumps the ice-maker to get the unit to fill before he leaves...Catriver..post back.
Posted on Mar 02, 2007
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Kenmore side by side ice maker sprays water into freezer
    Is it actually spraying out of the icemaker or is it running down the back of the freezer?
    Jan 31, 2013 | Kenmore Elite Sears & Other Brands...
    We have a Kenmore Elite refrigertor. The ice
    hi,please remove ice maker see if an ice is jamming it up first...second on the freezer ,when you open it up...is there a switch on the wall..that is a infrared for the icemaker,,if so switch it off...remove ice maker...check it first....if its ok...possible problem with sensor...check these things,,,is filter ok...is water coming out of door,dispenser...then filter ok....good luck call if need assistance,,,michael,,doctor airr appl.repair..843-384-8474...
    Mar 28, 2010 | Refrigerators
    Ice maker issues - what to do next?
    I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
    Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Replaced icemaker with new one but still not working
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
    Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
    Ice maker not making ice
    The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
    Jan 04, 2009 | Kenmore 53642 / 53644 Side by Side...
    • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser . The valve that the ice-maker relies on may be bad,
    • or it could be the ice-maker itself.
    • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
    • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
    • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
    btw- you can replace the whole icemaker system for around  $115.00.
    • charging you $250 for a $20 drive motor is ridiculous! my 12 year old son can change the drive motor in 15 minutes.
    Jul 06, 2008 | Refrigerators
    Kenmore Coldspot 106.56236400 Ice now and then
    replace the icemaker unit, also make sure if you are on a well system that your pressure is over 30 lbs, it is adviseable to purchase an icemaker kit, which will come with a new water valve as well. either one of the two may be at fault.
    you can make this repair yourself.
    Mar 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Installed replacement Icemaker but will not dump new ice...
    Either your freezer is not cold enough or you got a defective ice maker. It needs to be 15 degrees or colder to make ice. The water may be frooze but not cold enough to close the internal thermostat inside the ice maker. If your freezer is colder that 15 degrees, take the ice maker back to Sears, you got a lemon. Good luck!, Mack
    Jan 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Kenmore 53582 / 53584 Side by Side Refrigerator Logo
    294 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    Jude24
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
