Question about SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader
Locked 8GB Sandisk SDHC Card how to unlock?
I bought several 8GB sandisk cards but they all say locked when I try to use them in my cam. How do I unlock them?
  • Anonymous Jan 31, 2009
    Even with the side toggle switched to the unlock position, it remains locked.
  • Anonymous Mar 12, 2009
    I've tried everything and the card remains locked!
5 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: I need to unlock a Sandisk SD card, I've just
If you've already tried the slide switch, see this link for additional things that you can try.
Posted on Apr 02, 2010
SOURCE: SanDisk 8GB SDHC card cannot be read by either computer or T-Mobile Dash phone.
Solution :
Put the card in your phone, link the phone to your pc and format the card through your pc. You should see two additional drives, one for your phones memory and one for your card. I had the same problem with my phone but it is now sorted !
Paul
Posted on Oct 25, 2008
  • 64 Answers
SOURCE: my sandisk 2gb mem card locked and i dont know how to unlock it
slide switch on the side of card
Posted on Dec 09, 2008
robmcd27
  • 423 Answers
SOURCE: Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Posted on Mar 03, 2009
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
How do i unlock an sd memory card
Look on the side edge of the card there should be a little switch there if so change the position that should solve your problem
Apr 14, 2013 | SanDisk 8GB Ultra 15MBs SDHC SD Class 4...
I have an HP Photosmar R725, and I recently got an SD card for it. It says "CARD HAS WRONG FORMAT" and "Press OK to format card." When I do, it says it's locked. I have unlocked the...
The R725 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to use SD cards, 2GB and smaller.
May 24, 2011 | HP Photosmart R725 Digital Camera
I have a SanDisk SDHC Card class 4 4 gb and it won't work in my Canon Power shot SD630, I get a memory error that says card is locked, however card is not locked, what camera canI use this card in?
The SD630 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Your SDHC card can be used in any camera that accepts SDHC cards.
Feb 03, 2011 | SanDisk 4GB Secure Digital High Capacity...
I just got a Polaroid DVF-720 digital camcorder and I got a SanDisk 8GB SDHC card but it will not format it says format error Manual says it will handle up to 32GB SDHC card
Are you sure the SD card is working properly? Try using a card reader and format it on the PC.
Also, make sure the Lock switch is flipped to the "unlocked" state.
Dec 29, 2010 | Polaroid Video Cameras
Somehow we locked our Sandisk Extreme SD HC 4gb card. And now when we put it in the camera, it says card locked. Can anybody help how to unlock it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 03, 2010 | SanDisk Extreme III 4GB Secure Digital...
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
Can't formate a Sandisk micro sd hc
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 08, 2010 | Electronics - Others
Memory card error
is the lock switch fliped wrong
Aug 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
8 gb card unlock on canon elph screen
it should have a slide switch on the outer casing of the card... write protection lock.
Jan 22, 2009 | SanDisk 8GB microSDHC Memory Card with...
Open Questions:
See all SanDisk 8GB microSDHC Memory Card with MobilMate Questions
SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader Logo
1,069 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
