Question about Kenmore Elite 21086
Kenmore (Calypso) Elite Washing machine shows LD and LF!
Model # is 110.21086000 The washer starts to fill with H2O and then stops filling. The washer then begins to make an odd sound for about 30 sec and then that noise stops. This is when The LD appeared. I trie to restart 2 or 3 more times and had the same outcome. However, the LF did appear after a restart. Lost manual when moving. Can anyone help me! Thanks
  • sandraz Jan 06, 2009
    same thing happened to me any advice
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Posted on Jan 22, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Itshows LF what do i do?
LF code means long fill on the water supply,if it takes too long to fill it will shut down,remove the water fill hoses and check for screens in the hoses and washer water connections and see if they are plugged with sediment
Aug 30, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Calypso Washer is not washing clothes or spinning; getting LF error message. Water is going into the machine but no washing action.
Hi There
I'm Sending you the fault codes. Hope this helps you and get you in the right direction.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house
* Error Codes- LF for long fill or FH for no water detected.
o A plumber may need to be consulted if the pressure is found to be too low.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
921 people viewed this question
Sal De
 Brian Main
Brian Main
