Question about Gateway Computers & Internet
Bios settings for Gateway/Intelmotherboard E210882
MY PC DOESN'T BOOT FROM CD OR HARD DISK, ALWAYS BOOT SET UP OR BOOT FROM NETWORK
Posted on Jan 27, 2010
  • 69 Answers
The latest BIOS update can be downloaded <a rel='nofollow' href="http://driverbyte.com/intel-e210882-bios_freedownload/">here</a>
Posted on Dec 10, 2008
Intel p4 e210882 vgadrivers
Hello there!
You can go to Gateway page, and download all drivers for these particular board. its that simple!
Carl
Mar 04, 2014 | Gateway Intel E210882 4000762 Aa...
go here
http://us.gateway.com/gw/en/US/content/drivers-downloads
go to select my product from a list
hit desk top
then E series
then E-2100
then select your operating system
then hit "all" instead of just "latest"
if this is not correct you need to leave more info on what computer you have
I need to know how much main memory that supports my motherboard.
According to Intel:
(DIMM) sockets
• 800/667 MHz single or dual channel DDR2 SDRAM interface
• Support for up to 8 GB of system memory
Nov 10, 2012 | Intel Gateway E210882 Motherboard With...
Audio driver download
Go to your computer manufacturer\'s or your motherboard manufacturer\'s website and download the driver from there. Note that E210882 is not likely to be the motherboard number/model.
15.April.2014
Jun 16, 2012 | Intel Gateway E210882 Motherboard With...
Good day I want to use a sata hard disk and
you will need to put in your windows disc and press f8 or whatever you need to press to gain access to your bios settings once in set your pc to boot from cd not h/d it will begin set up for a new install and ask if you want to install a third party sata disk etc click yes at this and follow prompts, restart pc and change bios settings back to h/d detection should then work.
May 09, 2010 | Dell (E210882) Motherboard
E210882 is the number on the motherboard on my Emachine computer. i'm trying to disable the onboard video card with a jumpper setting so it will reconize a older but working pci 3dfx monster 3d card I put...
You can disable the onboard by visiting your bios.
On boot it will tell you to press del f8 f2 etc to enter the setup from there you can navigate around to disable the onboard and choose the lane your older pci card is in.
Oct 11, 2009 | Dell (E210882) Motherboard
My motherboard wont fit into any case ><
all motherboards have a size known as "form factor"
*********** baord is Micro ATX,
youll have to buy a case that can fit that motherboard in or buy another motherboard that will fit in your case, youll have to find out your dell model number to find the form factor, easiest way would be search your old motherboard number
Jun 04, 2009 | Intel D845GVSR Motherboard
Reinstalled xp with SATA drives not booting e210882 motheboard
Have you checked your HDD jumper? Make sure it's in the Master position. You can also use the Cable Select setting. For cable select, you need to go to the Bios and make sure that you select your desired HDD as the master drive for boot up sequence.
Apr 15, 2009 | Dell (E210882) Motherboard
Dell 8400 e210882 .hd on ide pri .error initializing pci express nic bridge. drive 0 not found. drive 5 not found.the hd is seen on drive 4,and tests ok.flop. and cd rom off in bios. where do i put ide...
When installing hard drive much sure that the jumpers are set to primary position or ds master on some drives. Make sure they don't conflict with other drive or cd rom.
Now if having issue with bios error download the lastest bios update and run it. If not sure ask a friend who has do it before and get some help. The error sounds like a bios upgrade is required to solve problem. Let me know how you go.
Mar 19, 2009 | Dell (E210882) Motherboard
Computers & Internet Logo
819 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
