Question about Philips SoundBar DVD Home Theater with Ambisound
Just got a philips hts8100/5 soundbar & am trying to update the firmware from v33 to v37, the problem is that it is not reading the cdr/cdrw that I have copied the update to, I have tried 6 different makes of media & 2 different burning tools with the same outcome "no disc", it reads music cd's & dvds though not dvds that I have recorded myself on my philips 3320. Heip please
  • matthecat Dec 29, 2008
    I have the same problem, when I put disc in. It shows UN DISC
  • Anonymous Feb 09, 2009
    Ik heb de software geupgrade van 33 naar 37.Hiervan met de PC een CDR gemaakt . Deze wil de soundbar HTS8100 niet lezen!!!!! Melding is UN CD/R (Unknow CD/R)
GazllFixIt
  • 103 Answers
SOURCE: won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Posted on Jan 10, 2008
SOURCE: Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Posted on Jul 10, 2008
SOURCE: Philips Soundbar HTS8100
put it in the bin
Posted on Sep 11, 2008
SOURCE: MY PHILIPS CDRW/DVD SCB5265 CAN READ CDs BUT CAN NOT READ DVD
I just installed Nero CD writing Software and Power DVD and it took care of the problem.
Posted on Jan 25, 2009
SOURCE: Hot to make Philips HTS6100 region free?
Figured it out unlock for HTS6100, it's the same as for HTS8100
1. Turn on
2. Press Eject
3. Press 9, 9, 9, 9, 0
4. Swtich it to standby
5. Turn the player back on & it should now be region free.
Posted on Apr 05, 2009
My Philips Htl2160 soundbar just quit working after I tried to upgrade the firmware! It won't light up that it's getting power! I disconnected everything and reconnected, but still nothing! Any ideas?
Updating firmware is dangerous as it configures the part before the software loads. If the firmware update fails or the power cuts it renders the item inoperable as you have found. You will have contact Phillips for either a replacement unit or for a zipped firmware file to reload again.
Nov 22, 2015 | Philips HTL2160/12 Soundbar 60 Watts
Why does my philips cdr 570 mini recorder does not take blank cd torecord
Wrong type of disc (needs CDR or CDRW) or the laser lens is dsuty. Try a cleaning disc
Aug 31, 2014 | Audio Players & Recorders
Unknown disc on philips ht9150/98
Did you try another disc?
Try other discs - preferably store bought. If it will not recognize store bought discs then you have a defective unit.
Is the "unknown" disc home made? could be that the homemade disc has not been created properly or is a type of disc that the unit cannot read.
May 04, 2014 | Philips SoundBar DVD Home Theater with...
I would to know my DVD drive, Lite-on DVD C LH52C1P can write or burn any DVD disc? my OS is WIN XP Pro SP3
Here's the general info for your Burner:
Write support: CDR CDRW Read support: CDR CDRW DVD- DVD-RW DVD+ DVD+RW Operating System supported: Windows 7 Windows VISTA Windows 2003 Windows 2000 Windows 98 SEWINVISTA Windows XP Max Write Speed: 9 MB/sec. CD 52 X Max Read Speed: 9 MB/sec. CD 52 X DVD 7 X
Jan 15, 2011 | Lite On LH-52C1P Burner
Philips cdr 950 keeps saying update tem senconds into recording from lp very frustrating
you may have to do a firmware update see if the website has a support page that has firmware downloads and how to burn them to a disk
Jan 03, 2011 | Philips CDR600 CD Recorder
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
Dec 29, 2007 | Philips CDR778 2-Disc CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Philips SoundBar DVD Home Theater with Ambisound Logo
627 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
