posted by bikerdei on Mar 02, 2007
When I try to transfer MP3 files from my computer to the SD disk I get about half a gig on my one gig card and them I get a pop-up box tha says "can not create file or folder" It always happens around the same number of files or memory used (150 files or 1/2 gig). I'm using XP OS and itunes for ripping files from CD to folder on my desk top and then attempt to copy them to card. Help please!
Best Solution
posted on Jul 03, 2007
The problem is that the formatting of the memory card. Most cards are formatted in the 'FAT' format, which has a limit of I believe 133 files on the root drive. I took my 1 GB memory card, and reformatted it in the 'FAT32' format. I am now able to fill my memory card to capacity, and yes, then HA90 does read the entire card.
Comment by ironhead3fan, posted on Jul 06, 2007
The solution listed by ramblin5 as the best solution is wrong. Read the posting from ironhead3fan, that should work for you.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 18, 2007
When I was looking at this product, I contacted the manufacturer and they made it clear the unit worked best with a 512 mb or smaller card. The problem is not with Sandisk or the SD manufacturer, it is with the HA90.
Solution #3
posted on Mar 14, 2007
I have the same problem on my 2 Gig SD disk. I called SanDisk and they said the Fat32 windows restriction will only allow so many files in the root directory. The rest have to go into folders. But this HA90 won't read files in folders - so I'm stuck with a 2 gig card and can only use 1/2 a gig of the space
Solution #4
posted on May 18, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Well I totally dissagree. I think the fault is with the card manufacturer for having a restricted root directory. When you buy a 1GB SD Card you would expect to be able to fill it. I have had the same problems.
Solution #5
posted on Mar 15, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Ramblin5,
Thanks, I figured it was something to do with windows, I wonder if MACs would have same problem?
I guess I will only spend money on 512 SD's then and just carry extras with me on the road
Suggest a new solution for this problem
Post a New problem for Harley Davidson Road Tech HA90 MP3
Email this problem
Email this problem
Can you Help with these MP3 and Digital Media Players problems?
Harley Davidson Road Tech HA90 (64 MB) MP3...
Harley Davidson Adjustable...
No mounting instructions came... Answer This...
Harley Davidson Road Tech HA90...
I bought a new 2GB sd card and... Answer This...
73 xlch sportster carburator...
have aftermarket carb on it,... Answer This...
how much oil goes in the gear...
1995 sportster 1200 Answer This...
what is the proper way to stat...
I have a 3 wheel Harley gas... Answer This...
Repair Service
Find MP3 and Dig. Repairman Near You:
