Question about HP Inkjet 1200dn Printer
Callibrating after every job
I have a business inkjet 1200. With recently changing the printhead, the printer will now callibrate after every job sent to the printer is printed. I have un-installed and re-installed the drivers for this printer, and the problem still occurs. Can someone help? Thanks
  • Nikia Jennings Mar 05, 2007
    I did what you suggested, and the printer went through its motions, printed the job, and then proceded to calibrate again. I was then patient, and let it do its thing. After it finished calibrating this time, it didn't do it anymore. I ran test pages from various programs, and no calibration page afterwards. THANKS!
  • 624 Answers
With the printer on remove the printhead and turn the printer off. Turn the printer back on again without the printhead and let restart. Once the printer has finished the startup process reinstall the printhead. Let us know if that works and please don't forget to rate this posting.
Posted on Mar 02, 2007
  • tomj23 Mar 05, 2007
    Thanks for the outcome, few get back to us.
SOURCE:
Brother HL-4040CDN printer colors are off, tend to be pink
There could be a number of causes for the problems your describing, but one of the most common causes of discoloration and issues with toner is a faulty ribbon sensor. A broken sensor will be unable to accurately read the ribbon and apply the correct color. I hope this helps
Sep 02, 2012 | Brother HL-4040cdn Color Laser Printer...
The speedo sensor isn't reading the true speed .it reads a lot faster than what bike is going. only had the bike a few days. no idea what to do
The speedo needs callibrating as you have either different sized tyres/wheels or the speedo has been changed.
Take it to a dealer for callibration.
Feb 01, 2011 | 2007 Gas Gas Pampera 450
On my HP Business Inkjet 1200 the black/magenta/yellow lights are flashing but not the cyan. Neither the printhead or ink cartridge light is lit. With 3 out of 4 lights lit what is the printer complaining...
You may be using non original ink catridges, the printer chip will not recognise so flashes as if needs replacing.if refills are original printer chip may need to be reset.
Feb 03, 2018 | HP Business Inkjet 1200dtn Printer
We have installed new inkjet cartridges for the inkjet 1200 printer, however there is no inkflow on the paper when printing documents. Please advise on what to do
Sounds like you need to replace the printheads. The business inkjet printers have seperate ink and prinheads. In home use printer models the printer cartridge is all in one with ink and printhead in one unit.
Oct 03, 2009 | HP Business InkJet 1200D Printer
Black in will not print.
Try this.
Take the printhead out of the printer.
Get a saucer and put it on the kitchen sink.
Boil a kettle pour one quarter of one inch of boiling water into the Saucer.
Place the printing part, where the holes the ink comes out of are, in the water for 10 seconds.
Place the part that was in the water on a paper towel and let water drain from printhead.
NOTE: Do not touch any of the metal contacts with you fingers!!!!
Replace in the printer and fit the cartridges.
Hope this works for you,
Apr 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printhead (R), Check Printhead - Canon IPF5000
that confirms Right Print head is may be Out of Ink or near to low ink level.
check whether there is any option to Disable Alerts in printing preferences..print settings >> printer settings
Feb 18, 2009 | Canon imagePROGRAF iPF5000 InkJet Printer
Changing printhead
I called in and they sent me a printhead I got it the next day great job
Nov 05, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer won't print
My printer will not print black ink. The color ink is very light. I replaced a new color cartlidge, cleaned the printheads and tried to callibrate, but the printer could not identify the callibration page from my scanner. Can you help me resolve my problem?
Thanks,
Carol
May 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lines on printed photos
Hi Have you tried cleaning the printer and doing a alignment for the inkjets? I believe under your printer properties you should have the option do to maintenance clean and alignment>when doing this it will use some ink but in order for the printer to function properly you sometimes have to do this. Hi hope this helps you!!
Dec 04, 2007 | Office Equipment & Supplies
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP Inkjet 1200dn Printer Logo
271 people viewed this question
Clive
Clive
Thomas F. Schneider
