Question about Brother MFC-8460N All-In-One Printer
My brother mfc-8460n printer allways prints from the manual tray. Ive checked all my settings in Windows and in the printer itself. Still every time I want to print a document from my PC it tries to pull from the manual paper tray instead of the selected tray 1.
    President:
  • Brother Master
  • 990 Answers
Sounds like after setting you didn't lock in, don't forget after setting you have to hit enter or yes key
Posted on Dec 13, 2008
I need a manual
HI,you can download the manual from the below link..
http://www.manualowl.com/p/Brother%20International/MFC-8460n/Manual/42499
Click on the user's manual and download...
Jun 27, 2011 | Brother MFC-8460N All-In-One Printer
Problem for Brother MFC-8460N error message no paper in tray tried cleaning. re loading, on-off. etc.
Make sure the paper guide is not too tight, also set the paper tray on a table and look at the gear on the side at the bottom. The flat part of that gear must be level with the bottom of the tray, if not the metal under the lifter is bent and needs to be straightened. also tip the printer on it's back and make sure the sensor levers by the feed roller move freely.
Dec 24, 2009 | Brother MFC-8460N All-In-One Printer
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
We have a Brother MFC 8460N and it says "NO PAPER." However, there is paper and the spring in the tray is working fine.
Yes check that the shutter is ok and also ensure that the LED sensor is free of dirty(Use blower)
Jul 27, 2009 | Brother MFC-8460N All-In-One Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
No Paper Message- when the tray if full
When removing the tray - turn off printer -
insert try with paper - turn on printer -
you should notice the blue paper meter moving. fixed
Oct 20, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460N Paper Jam
paper jams alway in the same spot- just as it's about to exit the bottom tray
Feb 08, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460N All in one
I found the problem was with MS Word. The tray has to be set to Tray 1 and not MP.
Nov 19, 2007 | Brother MFC-8460N Laser Printer
Brother MFC-8460N All-In-One Printer Logo
145 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
