Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
PT5598DH, when turning on, timer light flashes but no picture
Is this a blub problem that i can fix?
  • 20 Answers
Do not panic! Do not throw your TV away like I wanted to! Here is what may be the solution for most of the members who have posted their complaints here recently. I am not an expert, but I followed all blogs from various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it from www.partstore.com and since this Akai is the same model as a comparable Samsung Model, buy the Samsung comparable Convergence board for $77. It came to about $85 after shipping. Call them if you need the exact model #. The Convergence board has two black STK ICs and two colors of wires, a gray kind and a blue kind,all which have 'pins' and can easily be unplugged from the circuit board in the TV. It is basically a complete system that takes less than30 minutes to install. It is a simple swap procedure, with no soldering.You only need the new board and a screwdriver! Remove the lower backboard of your TV where the cables are plugged in (do not unscrew all the screws for the screen, as it is unnecessary, and might just damage your screen if you are not careful.) It has a u-like shape and comes off easy. Detach the gray wires connecting your old board to the rest of the circuitry, and detach the blue wires connecting the old board to the circuitry. On the old board, there are connectors marked,from left, blue, green and red. Detach those from the old board, and mark the wires so that you may connect the correct the wires to the new board. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks which held the old board, and screw the lone screw to the board. Plug the gray cables from the new board to the connectors where the gray cables from the old board were,and do so for the blue cables. Connect the multicolored cables to the blue, green and red, just as was done on the old board. Reattach the cover and test the TV. Please do not replace the two STK ICs only. When I removed my old board, I realized that there was a burn mark, where the ICs were, but maybe it was a fuse.You may replace the ICs only to discover that it was another problem.Good luck, and I wish you all the best in the repairs. I just saved about$100 for a repairman just to show up.
Posted on Dec 11, 2008
Day time runin lights flashin when you start the car and will not stay on also has blown the blubs on dim
the reason your lights flash like that is a warning that you have some problem with the lights.. i had the same problem, if you fix the blown blub it will stop
Jan 12, 2011 | 2001 Chevrolet Cavalier
I have an HL- t50756 and it turns off every 10 minutes
Try to reset the lamp timer. To do this get the remote first shut off the TV. Then on the TV remote (not cable remote ect) press MUTE
then punch in the numbers 182 then POWER in that order, wait when the TV starts up the Factory meneu will appear go to Options press, then look for Lamp Hrs. to see how many hours you have on your lamp TV lamps last appox 2 years average use. 4,000 hrs. Try this, above where you see the hours go to reset or something like that and press to reset blub timer to zero. Your blub might still be ok, but the timer says times up and tries to shut off the TV thinking the blub is bad. By reseting the blub timer to zero the TV will think it's a new lamp. Until it really goes then no picture at all or gets very dark. Try this trick it might solve your problem.
Good Luck!
Oct 12, 2010 | Samsung DLP HL-P5663W 56" TV
TV won't screen won't come on. You can hear it
Are you getting a soild red light and a blinking green, or both green and red blinking, that indicates your blub is toast. Time for a new lamp, I'm in the process of doing just that as mine bit the dust this morning. Up here in the great white North the blub costs $220.00. I your lucky and your down South you will pay about half that.
I've had this set since 05 and I am on my second lamp Toshiba paid for the first one not it's my turn, great set otherwise.
May 04, 2010 | LG 52SX4D 52" HDTV
Picture and sound going out- flashing lights
the problem its the main board it controls everything if no warranty go to www.shopjimmy.com better prices better than manufacturer and tv repair man
Apr 13, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
On/off green light flashes. Picture comes on for
the timer is set for a short time, try to get to the menu quick and turn off the timer it may take several tries.
Mar 06, 2010 | Televison & Video
MY SONY 006 IS FLASHING 4 GREEN BLINKING LIGHTS
U have power and sound right?The backlight video inverter board is the prob.
Sep 29, 2009 | Sony QUALIA 006 Television
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
