Question about GE JVM2050 Microwave Oven
My GE JVM1600 Series went out.
Need to get the microwave off the top of cabinet, got the 3 screws loose, will not slide out is there a template behind the micreowave to set the micro on? Need some help on this one, Thanks
  • GE Master
  • 9,098 Answers
You can download GE owner's manuals and installation instructions here.
It will help you, I'm sure.
Posted on Dec 13, 2008
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Tip
Change light bulb GE MOnogram Advantium Microwave oven
I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved
on Feb 17, 2009 | GE Monogram ZE2160SF Convection /...
I need the Top Cabinet Template and the Rear Wall Template for GE Microwave Model JVM2070WH02
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Apr 24, 2013 | GE JVM2070 Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
How do i change the heating fuse for a ge spacemaker microwave
unplug first, take three screws out of top vent cover and there may even be some on the top cabinet holding vent cover on front, then you might see fuse holder just behind vent cover, if not remove screw(s) holding touch pad on, then slide touch panel up and out. it will rest on hinge, then you should see fuse holder inside behind touch panel. BE SURE TO UNPLUG FIRST AS ELECTRICITY CAL KILL YOU.
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
GE JVM1650CH01 Microwave Template
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removal
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM2050 Microwave Oven Logo
537 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
