Question about Galaxy Radios DX-2517 CB Radio
I HAVE A 2517 GALAXY RADIO IT IS MUFFELD ON TRANSMIT
GALAXY 2517 TRANSMIT PROBLEMS WITH IT
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    what is it doing?
What is the power output on a watt meter telling you? if it is up above an 8 watt dead key with the rf power turned all the way down, someone has turned up the radio inside and you will ned to turn it back inside to get about a 2 or 3 watt dead key with the rf power turned all the way down on the outside knob on the face of the radio. to do this, you will need to locate the VR18 pot for low power on am/fm and the VR14 pot for high power on am/fm and adjust accordingly, you are most likely overdriving the radio in some way and if you are not familiar doing this sort of thing, then my suggestion would be for you to take it to your nearest electronics repair tech and have them do it for you. It is not a costly procedure and you will be better off to have an experienced tech in there. Also if you are running a power mic on it, try turning it down some or going back to the stock mic to see if the problem persists. If it does while running the stock mic, then most likely it's internal issues like the one explained above.
Posted on Mar 14, 2009
Galaxy DX-2517 CB Radio mic plug replacement
Its the same wiring as a cobra 29 so if you have one just match up what s there with what you go and you will be chatting in no time
Feb 05, 2012 | Galaxy Radios DX-2517 CB Radio
How to install echo board in a Galaxy 2517
  • This radio already has an echo board installed in it from the factory. On the bottom set of knobs, left side, over three knobs. That knob is your echo/delay knob. No need to install one. Just turn it on.
  • Hope this helps.
Nov 03, 2011 | Galaxy Radios DX-2517 CB Radio
Install Echo Board in Galaxy 2517
  • Hope this helps..
I have a uniden Grant like to wire up a 4 wire D104 the mic has white black red shield
Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
  • Pin 1 - Shield - Shield
  • Pin 2 - Audio - White
  • Pin 3 - Transmit - Red
  • Pin 4 - Receive - Black
Regards, Tony
May 05, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
My galaxy 2517 (NO TX)
if you have another radio put it right next to the 2547. turn on the monitor radio with no antenna on the same channel and key the 2547. if you can hear it the final transistor is bad. let me know if that worked
Jul 18, 2009 | Galaxy Radios DX-2517 CB Radio
Echo Problems
RF limited TBR-2 turbo echo board. It will plug in to the factory wires with no alterations. It will give you much more control.
Dec 13, 2008 | Galaxy Radios DX-2517 CB Radio
Super Star 3900 GHP
Can't help you there. It's most likely that you screwed the modulator up by extending the frequency range. I used to work for Galaxy and I know what happens to a radio when amateurs try to modify them (no offense). If you modify a high power radio such as your Super Star, you're bound to have modulation and SWR problems. In expert advice, never do amateur radio modifications to a high power radio. If you want a more versatile radio, get a Galaxy DX 2517 CB base station. The DX 2517 has PA/FM/AM/SSB/USB/LSB/CW modes, and bands A-F, and a frequency range from 25.615 to 29.205 MHz. The Galaxy DX 2517 has modifications that can be done right at the factory, they are optional however. The only thing I find annoying with the DX 2517 is that it's bulky, it leaves no room for any competition. When it was designed, the engineers left space saving out of the question.
Anyway, Good luck
and
Best Regards,
Gavin93
Aug 07, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy 2517
Sounds like to me that one or more of the switches are dirty. Open the unit with the power disconnected and purchase a spray can of electrical contact cleaner. Spray all of the switches and volume controls on the inside. Rotate all of the controls several times, back and forth to work the contact cleaner into the controls. Repeat as necessary. Over time, these switches get dirty and they don't make a good connection. The cleaner will restore continuity to the switches.
Good Luck,
- Jim
Oct 23, 2007 | Galaxy Radios DX-2517 CB Radio
Radio Communications Logo
215 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
