Question about Samsung TX-P3264 32" TV
32" HD flat screen (160 lbs) screen display became too wide
I noticed just a couple days ago that the edges on the left and right are about an inch cut off which is ruining my video gaming. Changing the menu settings doesn't help.
Bottom left and top right corners, the color is off almost as if a magnent is near the screen
Posted on Jun 21, 2009
Vizio 32 inch thin black vertical line on left side of screen
it is very likly you have problem with the buffer boards, sometime help to unplug conector and reconect, also check the smd fuse located on one of the boards since there are 2 buffer E&F.
Jan 09, 2013 | Vizio 32" Lcd Hdtv E320VA Hdmi Hd Tv Flat...
Left half of screen dimmer than right
same issue with my 47le5900 - I have fixed it... if I look through the back panel I can see a circuit board on the right... coming out of this at the top are two flat data cables, each about 1 1/2 inches wide, one is labeled (L) the other (R), it seems the (R) one was a little loose, so I pressed it downwards with a small screwdriver, problem solved.
Jun 25, 2012 | LG 42LE5500 42 in. TV
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
Nov 10, 2011 | Sharp Televison & Video
After turning the tv on after buying it yesterday, we noticed that there was a line on th opposite side of the screen, sort of a faint line, like when you watch shows that arent wide screen, well yeah...
business 10000: Buying T-CON/ caps for the TV that just bought a couple days ago?
Are you talking about black bars on the left and right side og the pictures? Try using 'FORMAT', 'ASPECT', or 'ZOOM' on the remote to fill up the screen.
Dec 02, 2010 | Televison & Video
We left our 40 inch ACER televison on the same channel for a couple of weeks. Now in the upper right hand corner is an image that won't go away. Is there a fix?
Im guessing this is a plasma television. Either replace the panel(very costly) or display a bright white screen on the tv and leave it like that for a several hours.
Dec 28, 2009 | Acer AT3205-DTV 32 in. HD-Ready LCD TV
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Widening around the border of picture
I suggest you read your manual.You likely have the picture setting on Panorama or Wide setting, and your manual should explain that Wide Screen pictures are stretched at the sidea to fill the screen.
Mar 03, 2008 | Olevia LT32HVM 32 in. LCD Television
Sharp Aquos 32" screen size too big!
Check your cable remote. You might have it set to HD zoom. This happened to us when our little girl got a hold of the cable remote.
Dec 05, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Open Questions:
Samsung TX-P3264 32" TV Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
