Question about Dual Electronics CECT P168 Cellular Phone
Cect i9 wont charge battery is fine
When you plug the charger into the phone it doesn't recgonise that the charger is plugged in and so won't charge
  • 10 more comments
  • flthapain Dec 17, 2008
    Just got cect i9, wont power up
  • Anonymous Dec 20, 2008
    usually when i plug in the charger the battery shows up on the screen ...but recently that hasn't been happening
  • Casey Worth
    Casey Worth Jan 02, 2009
    I'm not sure but I think the batteries are getting damaged when a bad connection on the data cable.
    I have just purchased two i9 phones and now have two of the four batteries that came with the phone giving me the same issue.
    The screen went black on both when the changer was connected.
  • coffeegirl7 Jan 13, 2009
    I have the same problem.
  • Anonymous Jan 16, 2009
    have the same prob. mine wont charge either!
  • Anonymous Jan 24, 2009
    I am regretting this phone- when we got the phone it looked like it was charging- left it overnight- first battery- no luck- second battery no luck- I tried a new cable- no luck- anybody know what to do?
  • Anonymous Jan 27, 2009
    I totally know what you guys are all talking about. I believe it may be bad manafacturing, however I am going to try a new cable before saying that for certain. For those of you (like myself) who dont have money to go and buy another phone and would like to figure this out there are battery chargers for the i9 batteries floating around ebay, so you might want to pick one up. That is my next move!
  • lee2811 Feb 02, 2009
    yes i have the same similar problem, the i9 batterys do not work in my i9 phone for some reason ive tried 3 and none work they dont charge either, so i tried a sony ericsson w800 battery and put it on the terminals of the i9 and it works (how strange). i tried the charger and that also worked, just a shame the battery doesnt fit in the phone, so you have to hold it. I dont get why the i9 battery dont work and the sony one does, its a pain really as now i cant find a battery that will work and fit it
    my email address is goldfinger2811@yahoo.com
    help me if you can
  • dsimmons34 Feb 05, 2009
    phone wont power up or charge
  • chiggins Feb 18, 2009
    I got the cables off ebay, and before i even tried to charge the phone, the cable broke, so i guess i'll try the sony ericsson w800 battery and just tape it in or something. The new charger i got doesnt work in the wall, computer or car. i9- more trouble than its worth.
  • mscoop95 Mar 07, 2009
    I tried all of the suggestions here and my i9 still wont charge.
  • Anonymous Apr 19, 2009
    i had my i9 (and used it every day) for over a mnth before it wouldnt charge anymore. I put the phone awa somwhere but found he spare battery, i see the two tabs on battery. n e way will it be worth me diggn the phone up, is this a fix?
The I9 battery charger is th problem. There is a small tab on the bottom edge of the batery that allow it to clip in the phone. This tab prevents the battery from going all the way into the charger which causes a missalignment with the contacts and due to the contacts being very thin they tend to break off. If this happens you must use the USB cable to charge the phone, it plugs in under the charger. If your contacts are good you can take a thin knife and ease the tab over the edge of the plastic lip on the charger alowing the battery to seat correctly in the charger making the proper connection.
Posted on Feb 25, 2009
The issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Posted on Feb 04, 2009
The problem is the "intelligent" charger...
I9 as the same problem as LACROSS battery charger. While the battery is too low, the charger dont see it and dont even try to charge it.
The way to make charge with low battery is to:
- remove i9 battery cover(let the battery into the i9 phone)
- plug usb cable to i9(i9 is not able to charge the battery right now)
- connect, in parallel of the i9 battery, 3 AA battery (serial) for few second until the charger see the battery.
Then the charger will see the battery and will charge it (You will see the i9 display showing a battery).
' +' ---- '+AA-''+AA-''+AA-' ----'
' i9 battery -' ---------------------------------'
'_________'
Posted on Dec 21, 2010
    Problem Solver:
  • 18 Answers
The w800i battery does work fine, its nothing to do with the cables, the only problem with the w800 battyer as its about a 1 or 2mm long so you may have to shave the battery down if poss or the inside of phone
Http://www.bestofferbuy.com/USB-Powered-Universal-Cell-Phone-Battery-Charger-Keychain-with-A-p-6747.html?currency=GBP&utm_source=gbase&utm_medium=cse&utm_campaign=gbase
This site sells the USB Powered Universal Cell Phone Battery Charger Keychain with Auto-Polarity (USB 5V) for £1.84 - they ship free of charge to loads of countries - might solve the problem as I'm having issues charging my batteries in the phone
Posted on Mar 24, 2009
I just bought two of these i9 phones on ebay and I am also having problems charging the batteries. surely there must be a charger available to do the job? the pins in the charger do connect to the battery as far as I can see everything light up green but still wont charge I am waiting a solution from the seller or they go back,,
Posted on Jun 22, 2010
    Problem Solver:
My phone got red hot in about an hour when plugged in to the USB charging cable. Still no charge, 3 batteries and 2 cables later I am giving up on the i9, nothing but junk
Posted on May 25, 2010
I had the same problem as well
but i realized since the taps are the one's preventing the battery to fully go in.
that maybe if i tried the metal parts jus connecting that to the charger's metal, perhaps it could work.
And it did. the only problem is
you must have the charger upside down on the power outlet
so it will stay in place. since the battery isn't fully in, as it must be slanted. It might get frustrating to get it to stay, but it'll end up charging
Posted on May 15, 2009
Phone won't come on
my name is Larry and i have the exact same phone. If ur lg isnt turning on and wont charge it could be couple things . either the charging port on ur phone needs replaced and or ur charger has gone bad i would take it to a cell phone repair shop close to you.
Mar 25, 2013 | Net10 LG Optimus Logic Cell Phone
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I hace a cect i9 phone still in box, but will not turn ON. It worked the first day I bougth it cause I tested it.I have charged the battery but still will not turn on. Is there a service location in...
you should have 2 batteries with it ...take battery out put other one in making sure in correctly seated...plug into pc via usb see if charging icon comes on ...once enough charge in to startup phone try other battery ...when charging you can press and hold top button on phone to startup if enough power...
Sep 11, 2009 | Dual Electronics CECT P168 Cellular Phone
My usb for cect i9 does charge phone
my cect i9 was not charging from usb I though it was the cable but after I took out battery and scrapped the 3 contacts on the batttery with my fingernail it started to charge and be recognized by computer again
Jul 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 not working
Take the battery out, towards the bottom left are 2 slits (sim one and two)
The **** closest to the back is sim2 which the card goes in with the gold chip facing you, the other **** next to it is sim one, with chip facing away from you
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Usb not recognise
TRY PLUGGING IT INTO A DIFFERENT USB. IF THIS DOESNT WORK TRY CHECKING DEVICE MANAGER ON YOUR COMPUTER, THEN USB CONTROLLERS TO INSURE YOUR PORTS ARE FUNCTIONING CORRECTLY.
Jun 21, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 3G won't charge
I have the same Problem me and my sister both bought one about 2 months ago and now they wont charge :( such a waste of money and both batteries wont charge. Because they are from hong kong i dont know what to do ??
Jun 04, 2009 | Dual Electronics CECT P168 Cellular Phone
CECT i9 GET WARNING WHEN CHARGING
Sounds like a bad charger you might need to get a replacement unit I had the same issue with one of my phones and it was a bad connector on the charger
Jan 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
6,049 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
