Question about Toshiba 57H81 57" Rear Projection Television
Power Problem when i plug the tv in it powers on then goes out and the red power light blinks. I have not a clue what could be wrong? Any suggestions?
I had the same thing happen about a year after I bought this model in late 2001. I had to call in a repair person to get it fixed. It was, I believe, a convergence board that blew out. It cost about $400 for the repair but the TV has worked fine since. The repair person said this was a common fault at that time with these Toshiba rear-projection sets.
Posted on Oct 06, 2007
SOURCE:
Blinking red light
your set goes on protection , problem in main board .
Sep 01, 2013 | Philips 42PFL3603D 42 in. LCD TV
Lamp or power?
Thats a lamp switch error. You need to keep trying to reseat the lamp till it goes away.
May 07, 2010 | Sony KDF-50E2000 50" HDTV
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Akai TV troubleshooting
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Televison & Video
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
