Question about JVC SR-DVM70 DVD Recorder
Jvc dm70 mac won't read camcorder!
I have a JVC DM70 camcorder. I bought a firewire cable and am able to connect from camera to computer.
My MAC (g5, running Leopard Operating System) doesn't read the camcorder when connected.
SOURCE: Problem connecting JVC GR D370U
I have JVC GR-D270 cam how I can copy my video from tap to my Laptop
Posted on Dec 22, 2007
  • 205 Answers
SOURCE: Need Help with my JVC GR-D750U
You say you have a firewire cable so I'm guessing you realize there is a difference between the firewire cable and the USB cable. You cannot transfer video with the USB cable.
What is your operating system XP, Vista or something else?
When you plug in the firewire cable to the camera and the computer and then turn on the camera does anything happen at all? I cannot recall the exact message, but you should see a small pop-up in the taskbar that something about detecting a DV device.
If you don't see it there may be a variety of problems, but I would still open a video capture application to see if the software "sees" the camera. Windows Movie Maker will work, but I use another product called Scenalzyer. You can download a free copy of Scenalzyer at www.scenalyzer.com. The demo copy is fully functional, but it will leave a "watermark" on your video. You'll need to pay for it to capture video without the watermark.
Assuming you try one of these software packages and you do not have any success I would do the following: right click on My computer and select properties, now select the Hardware tab and finally click on Device Manager. Look through the list and see if you can find something like 1394 Host Controller. If you find it, does it have any exclamation points or question marks next to it?
If none of this helps let me know and we can try some other things. Lastly, I want you to know that I'm not paid for this. It's a strange hobby know, but I like helping when I can. If you find any of this helpful (even if it does not ultimately solve your problem) I hope you will rate this positively. Thanks and good luck.
Posted on Jan 02, 2008
SOURCE: driver in windows XP
Use this guide:
http://www.jvcpro.co.uk/getResource2/install_sr-dvm70.pdf?id=6345
It's for a different model, but it works the same.
In a nutshell, when the "AV/C Tuner" driver request comes up, just cancel the install. Then, it will want an "AV/C Tape Recorder/Player" driver. It "should" install automatically and be instantly recognized. If not, follow the instructions in the guide.
There are also instructions in there for disabling the "Av/C Tuner" every time the deck gets connected. Hope this helps - worked for me! - cliffpro.com
Posted on Mar 21, 2008
SOURCE: Problems playing dvds recorded from camcorder tapes
Did you finalized the dvd?
Posted on Aug 31, 2008
  • 5 Answers
SOURCE: record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
Posted on Nov 14, 2008
I have an apple laptop, how do I transfer from my camcorder to a dvd on my apple.
You do not need drivers to get the footage from tape to a Mac. You do require a firewire cable and use iMovie or Final Cut to capture.
Oct 04, 2016 | JVC Everio GZ-MG21 Camcorder
Connecting with a Mac computer
which type of mac if latest you need firewire 800 to connect the camera to computer
Dec 13, 2013 | JVC GR-DVL300 Mini DV Digital Camcorder
I,ve purchased a apple mac and can,t get my jvc 700x to comply with it
In order to import video you have to connect your computer to the DV in/out connection on the side of the camera. In your manual its on index page 6 and its the connection on the side of the camera #25 in the index. You have to have a DV cable that connects one side to the DV out of the camera and usually a firewire port on your computer. USB connections usually don't work for importing video to your computer.
Here is a link to the manual http://resources.jvc.com/Resources/00/00/95/LYT1280-001B.pdf
Feb 29, 2012 | JVC GRDX77 MiniDV Camcorder
Hi, I have a JVC GR DVX 707EK Camcorder and wanted to know whether I can buy anything thyat would enable me to downlaod the videos done directly onto my PC or MAC. Any assistance would be appreciated
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
Nov 30, 2010 | JVC GR-DVX707 Mini DV Digital Camcorder
What kind of cable do i need to use from camcorder jvc gr-d33u to pc?
This camera cannot send video to most PCs. It doesn't have a USB connector. There is something called a DV connector, but it is very unlikely that your computer has this. This is also called a Firewire connector and can often be found on the Apple Mac.
You can get an add-on PC card to fit Firewire connections to a PC. If you do this, you will need software (supposed to have come with the computer or you can use third party software) to do the transfers, and a cable JVC VC-VDV206U. This is however just a normal Firewire cable- though you want to be sure that you get the kind with a small connector at one end for the camera and a larger connector at the other (six pin) for the computer.
You can download a copy of the manual at
this link
Oct 20, 2010 | JVC GR-D33US Camcorder
JVC GR-D50 not seen by PC or Mac via Firewire
Could it be a bad cable or a bent/broken pin where the cable is connected to?
Nov 11, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Help meeee pls! JVC mini DV cam problems
just joking althoe macs are crap tho,you need a firewire cable and firewire support on your mac its that easy,you just plug in and the pc does the rest,not sure about mac thoe cause there crap
Jan 03, 2007 | JVC GR-D370 Mini DV Digital Camcorder
JVC SR-DVM70 DVD Recorder Logo
120 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
