Question about Poulan Pro Chain Saw 46cc 20"
Fuel mix adjustment screw fell out
Found part & put it back in need to know proper adjustment for it
  • cuzzmo Dec 17, 2008
    Right on the money!
  • 211 Answers
Hi
First take a screwdriver and make a sign on it.Check and note how many turns are at Low speed ."L" adjustment.Then adjust High speed "H" at half a turn less than "L".Idle speed "T" adjust accordingly.
Start the engine.
best regards savumihai71
Posted on Dec 10, 2008
I have a magnum 1012 and did a simple rf tune up by adjusting the rf pot now won't tx checked final ok now what?
You probably adjusted the wrong one. Put the POT back to where it was, and hope that things start working again. If they don't you are going to need to take it to someone who knows radio electronics, and has the proper test equipment, in order get the unit working again.
Jan 22, 2014 | Magnum Radio Communications
Need to figure out how it goes back together
Just like the person above commented....The good thing about doing one side at a time, if you forgot how it goes back together just look at the opposite side of axle as a guide so you can properly re-assemble. One side at a time! It is recommended to replace your old hardware with new at 100,000 miles. The Hardware kits are inexpensive to replace. Remember to adjust the new brakes with the adjuster sleeve and use the drum as a guide so you know you have them adjusted close. As a final step to adjust brakes when finished, safely drive vehicle in reverse applying brakes, this will put the final touch on the automatic method of adjusting your brakes.
Nov 13, 2012 | Cars & Trucks
Serpentine belt comes off a lot. how to put on to save money?
Is the serpentine belt broken or cracked? If it can be salvaged, put it back on, then check for the adjustment. There should be an adjustment bolt on the alternator that will tighten it up. Also, never assume that they give you the correct belt at the auto parts store. Check with a dealer. I had the same problem with my Nissan and found out the parts store gave me a belt that was an inch too long, so even when I adjusted it out, it still wouldn't fit properly.
Dec 20, 2010 | 2000 Dodge Grand Caravan
How does the belt tensioner go back on the pick
I think your best bet, after making sure you have the proper belt that isn't too short of course, and that it is routed properly through your pulley assembly, is to get a photo diagram of your engine assembly where you can see the tensioner...try google images. Then you can replicate the tensioner position.
Jun 06, 2010 | 1997 Nissan Pickup
Idle issues with 96 Chevy cavalier 2.2L OHV. everytime i try to adjust RPM's i get idle too high code. after doing research found that stop screw on throttle is factory set and should not be messed with,...
WHEN YOU MOVE SCREW YOU CHANGE TPS VOLTAGE READINGS YOU WILL NEED TO MONITOR TPS VOLTAGE AND ADJUST BACK TO SPECS DONT KNOW EXACT BUT SHOULD BE AROUND .50 AT IDLE
Mar 17, 2010 | 1996 Chevrolet Cavalier
I ADJUSTED THE BONNET GROMITS TRYING GET BONNET TO SIT LOWER ,THEN FOUND COULD NOT GET BONNET TO RELEASE, AFTER LOADS OF ATTEMPS I FREED IT AND FOUND NOW ONLY WORKS IF SOMONE HOLDS PULLER IF I PULL BONNET...
your going to have to readjust the bumpers, there has to be tension so the hood pops up, try adjusting the latch to get the hood to close even, try that but put the bumper back or adjust acording to the latch adjustment and sprak latch good with wd40. good luck.
Jan 27, 2010 | 2001 Hyundai Accent
How do i get the proper clutch ajustment on a 1989 xlh 1200 sportsters.i have the slack out of the cable and all the play out of the clutch ajustment screw.now what do i do next?
Ok, let's start back over again. To properly adjust the clutch, you MUST do it in a particular method due to the design of the release mechanism.
First, you must "unadjust" the cable. Find the cable adjuster and "unadjust" it making the cable as short as possible, lots of freeplay in the cable.
Then, remove the clutch access cover and remove the spring and the "lockplate" that looks like a nut with a stem on it.
Turn the clutch adjusting screw counterclockwise to remove all the free play.
Now, back off on the screw 1/4 turn.
Then reinstall the "lockplate". if it doesn't want to go back in, you may have to rotate the adjusting screw clockwise just enough to get it back in. Put the spring back in and put the clutch access cover back on.
Readjust the cable so that you have a freeplay at the clutch lever of about a eighth (1/8") inch freeplay or about the thickness of a nickle.
Lock everything down and this should be correct.
I have found that sometimes you have to "tweak" the cable adjustment to get a clutch to engage exactly where a particular rider wants it to start engaging. This is a preference type thing and has to be done on a "trial and error" basis with the cable adjustment. But, you must use this method to adjust the clutch down at the engine end of the cable. Good Luck!
Dec 20, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Why does my aprilia rs 125 clutch pressure plate keep breaking?
if your not tensioning them properly and evenly they will do that
have you also replaced the springs?
you really need the manual to do this if you are not familliar with the procedure.
Nov 13, 2009 | 1999 Aprilia RS 125 Extrema
2004 ford f350 4x4 dually is very loose while driving
Well it could be that you need to have the steering box properly adjusted tightened up a bit when you put the new steering box on it has to be adjusted by someone that knows how to adjust it properly or you might need to put a stabilizer shock on the front end or if it has one already replace it.
Mar 18, 2009 | 2004 Ford F350
Singer fantasia II problem
Check the reverse lever.
Most probably it's stucked in, the last time you used it.
Jun 08, 2008 | Singer 3116 Simple
Poulan Pro Chain Saw 46cc 20" Logo
73 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
