Question about Whirlpool GH7145XF Microwave Oven
Whirlpool self cleaning oven overheating and lock
My Whirlpool oven RBS305PQ9 put itself on a self cleaning cycle after I selected the bake at 350degree option. A service provider came out to fix it - replacing the thermostat. 3 weeks later the oven did the same thing, but this time the door closed. I got the previous service provider out, who used a coat hanger to open the door. when the oven locked an error message appeared but I did not really take notice of it. The service provider now wants to replace the board at $350 (previous work was $307. Any help would be appreciated.
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for maybe an hour. Then let us know if the hard
    reset does not fix it.
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool GT4185SK Keypad does not work - oven starts as soon as door is closed
Is it possible that some spray cleaner accidentally got into the controls?
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
Another thing that can cause this is steam or grease / smoke getting in the controls. The best way to prevent this is to be sure your hood exhaust fan is on whenever you cook on the stove top.
If it does not dry out over time, it may need to be manually dried or blown out.
I've followed up to your by e-mail address to be sure I help you fully.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: MIcrowave oven stopped heating - Whirlpool MH6150XMS
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Posted on Mar 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: door handle
I recommend that you do not remove the door or hinges to do the job because if it's not aligned exactly, you can have microwave leakage.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Apr 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
rickzilla
  • 706 Answers
SOURCE: Whirlpool Microwave Oven GH9185XLB1
You may have a bad control board. Have you tried unplugging the oven and then reapplying poqwer afterwards? Manytimes , when elcetronic control logic gets corrupt, a power down/up reset clears the problem. If it continues, I would consider replacing the control board..Here is a link to the circuit board you might consider replacing.. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059895&PPStack=1
These kind of things are generally trial and error and there is no guarantee that this will be the solution to your specific problem..
Hope this helps...
Posted on Sep 09, 2008
I have a whirlpool oven. I ran the self cleaning cycle,let it cool down for a day and ride to open the door. It wouldn't open. I then cycled the circuit breaker and tied again. No good. There appears to be...
sad to say but way too many of us have gotten lazy , even I do at times but self cleanings ovens have always been a problem. the excessive heat required is costly and burns up many elements among other things
Oct 29, 2017 | Whirlpool RMC275PVQ Built-in Microwave...
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
How do I use the self-cleaning function on my Whirlpool Super Capacity 465 self-cleaning oven?
If you just want to run the basic self-clean cycle. First remove the broiler pan and racks from the oven. Next clean any heavy spills up with a non-abrasive cleaner (do not use an oven cleaner). Clean the window of the oven door and the door frame (to the outside of the gasket). Then close the oven. If the oven has a touch-pad, press the Auto-clean pad on the oven followed by Start. The oven will automatically lock and then unlock when the oven has cooled after the cleaning cycle. (I'm less certain of the control settings for the dial type of oven control.)
In order to get your manual you need the full model number of the oven. This is on a plate located behind the storage door. This pdf, http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf , gives you a picture of where the model and serial numbers are is on page 4 as well as some of the information contained in the serial number on the subsequent pages.
Once you have your model number, go to http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number. This should let you get the manual specific to your oven.
I hope this helps.
Apr 26, 2011 | Whirlpool Microwave Ovens
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
Frigidaire wall bake oven (door opens with hinges on left) won't unlock after cleaning. Turned current off and back on with no results. Fan runs as in cleaning cycle, but door won't open.
If after self cleaning cycle the over door is not getting open.Then in some cases the door latch gets locked and this latch stops functioning so the door does not get open.In this case the front door assembly has to be disassembled and the door latch,it has to be manually triggered/pushed by a screw driver or any such object.So the door latch releases the door to get open.Then refit the parts and check,if the door latch is not functioning as it should be.Then the door latch assembly has to be replaced.After self cleaning,many a times the door latches gets overheated and its connections gets short internally.This is noticed by many other users too.In some cases door latch just gets blocked and triggering it with screw driver,makes it function properly.So disassemble the door and see the condition of door latch.This will help you to decide whether its just locked or got faulty.------------If its got faulty and you require door latch part,then you can get it from the online sites like www.repairclinic.com or from searspartsdirect site.
---------------- This should help.Thanks.Helpmech.
Dec 24, 2010 | Microwave Ovens
How to use self cleaning oven?
  1. Remove oven racks and soak them in soapy water.
  2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  3. 3 Let the oven do its work;it will heat for several hours, charring off baked-on .foods
  4. Fast Cleaning
  5. 1 Remove oven racks and place them in soapy water to soak.
  6. 2 Preheat oven to 200 degrees.
  7. 3 Turn the oven off and spray the inside with oven cleaner.
  8. 4 Allow to sit for 10 minutes.
  9. 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  10. 6 Dry with a soft cloth.
rate this if it help
Thanks.
Oct 15, 2010 | Microwave Ovens
The oven door remained locked after self- cleaning. Ran the cleaning cycle again it still stayed locked. Also tried throwing the breaker.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | Magic Chef Microwave Ovens
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Whirlpool GH7145XF Microwave Oven Logo
264 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
