Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Water looking droplets on inside of blue lens
Blue lens has water looking droplets in it. please help causing blue out line.
    Genius:
  • 1,030 Answers
Droplits are more than likey air. sound like a glycol leak on the blue tube. look for liquid underneghth the tube. THis would require replacement of blue tube.
Posted on Dec 10, 2008
After being in storage my etx has condensation spots in side on lens how can i remove these '
It is also possible this is mould, if the scope has been in storage. Mould looks different however, a brown spot or two. Condensation of course is water droplets.
Weasner's guide to repair may assist if you need to get inside
http://www.weasner.com/etx/techtips/2012/Xephius's_Updated_Repair_Guide.pdf
http://www.astronomyforum.net/etx-telescope-forum/124524-dissassembly-my-ota-pics-etx125ec.html
Dec 19, 2015 | Optics
Water droplet
if it is rechargable camera ,put it on charge then stand the camera up so it can dry up
Jan 05, 2014 | Nikon Coolpix S1 Digital Camera
I have moisture inside my headlight on my 2007 gmc denali. will i have to replace the entire assembly. The lamp is out, could that cause the moisture. Or does the moisture cause the lamp to burn out.
{: ) Some exterior lamps, such as cornering, turn signal, backup, headlamps or tail lamps may exhibit very small droplets of water, a fine mist or white fog (condensation) on the inside of the lamp lens. This may be more noticeable on lamps with "multi-lens" designs and may be normal during certain weather conditions. Condensation occurs when the air inside the lamp assembly, through atmospheric changes, reaches the "dew point". When this takes place, the moisture in the air within the lamp assembly condenses, creating a fine mist or white fog on the inside surface of the lamp lens.
Most exterior lamps on General Motors vehicles use a vented design and feature a replaceable bulb assembly. They are designed to remove any accumulated moisture vapor by expelling it through a vent system. The vent system operates at all times, however, it is most effective when the lamps are ON or when the vehicle is in motion. Depending on the size, shape and location of the lamp on the vehicle, and the atmospheric conditions occurring, the amount of time required to clear the lamp may vary from 2 to 6 hours.
Completely sealed headlamp assemblies (sealed beams) are still used on a limited number of models being manufactured today. These lamps require the replacement of the complete lamp assembly if a bulb filament burns out.
If moisture or droplets appear after being exposed to rain or washing, you can try putting some weather seals on the edges where you think the seal is poor. Check also the headlamp caps. In any case, if the moisture doesn't clear no matter what drying approaches, better replace the assembly.
The bulbs won't cause the moisture, but it is possible that an accumulated moisture on the bulb itself can disable it, although rare.
Jun 27, 2011 | 2007 GMC Yukon Denali
The bulb on my wifes trailblazer keeps blowing.
the most common cause for a bulb to repeatedly blow is water getting into the light housing. its supposed to be sealed, but sometimes they do leak. next time you wash it or after good rain, peek inside and see if you see water droplets inside the lens. if so, the entire housing needs to be replaced.
Feb 21, 2010 | Chevrolet Cobalt Cars & Trucks
Dried water droplets on inside of lens
The camera lens will have to come completely apart, and all the pieces be cleaned. This is not something you can do yourself at home. Because there is water in the lens, there is the risk that the humidity will cause corrision of some of the pieces and electronics inside of the lens unit.
You an try leaving the camera in a dry warm place that is not more than about 100 deg F for a few days to see if the water will dry out. But, I am sure that there will be water stains inside on the lens surfaces.
Jerry G.
May 16, 2008 | Olympus Cameras
Weatherproof
The Stylus Verve weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus Verve is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Weatherproof
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Weatherproof
The Stylus 500 weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus 500 is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Weatherproof
The Olympus Stylus 300/400 Digital is the first metal-bodied digital camera in the world to feature protection equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, viewfinder, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus 300/400 Digital is designed to operate at ambient temperature 32°-104°F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and can not be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
