Question about Nortel Norstar 16-Line PBX Speakerphone
Pick up and hang up
I want to be able to answer and hang up my calls w/out selecting a line or pushing RLS how do I do this?
  • 32 Answers
Answering a call on a meridian phone can be determined in software by giving priority to the line that is ringing rather than the one that is configured on the first key key 0.you can have several lines on the phone and in this way when you lift off, the line that is ringing is the one that is answered automatically rather than having to press the actual key itself.so unless you are familiar with the s/w overlays it will be hard for you to change your current setup yourself
Posted on Dec 19, 2008
Handsfree stays on when you hit "rls" it hangs up the call
rls is release , is the hangup button (hook switch) working (under the handset)
Apr 07, 2014 | NorStar Meridian M7310 Phone
How do I tell my 2820 to prepare to receive an incoming fax? My phone line and my fax line are the same number. It continues to ring but the fax machine is not answering. I have also turned the answering...
To have the machine answer faxes and record voice messages unattended change the answering mode to message centre. If you are home and pick up the phone , but it is a fax, not a phone call push *91 on the phone you answered on, and hang-up the phone. the fax machine will tyhen start receiving.
Dec 27, 2010 | Brother IntelliFax-2820 Laser Fax
Norstar m7310 needs rls button pushed after every call
I've seen this many times; Check the Handset cable. It is probably plugged into the Headset connection on the phone.
Sep 23, 2009 | NorStar Meridian M7310 Phone
Picking up and Haning up problems. "Rls" key "Line 1-4" keys
Can you sheck something for me; under your phone where the cables are plugged into, there are 3 types of jacks... 1 jack is to plug the phone into the wall 1 jack is to plug the handset into(picture of phone handset) 1 jack is to plug a headset into(picture of headset)
Check and make sure that the handset is plugged into the handset, and NOT the headset jack... and move the cables if that is the issue. Your problem sounds very familar to your handset being plugged into the wrong jack on the bottom of your phone, and it is more common than you think.
Aug 20, 2009 | NorStar M7324 Telephone
Well I'm on reception and when I put calls through sometimes the other person on the other line has to push the call to pick up.. It only happens every now again. Most of the time I put the caller on hold...
Save yourself some time and decide how you want to process calls. If you press the DSS button directly, the outside line will go on hold and the inside party is rung. When they answer, if you hang up, the outside held call is immediately connected. If the inside party hangs up first, the outside held call stays in hold.
I would use the procedure "may I tell him who's calling?" Announce the call to the inside party as "I have a call from so-and-so" If they accept, you hang up.
Now, if you have to locate the inside party, press HOLD, then dial the extensions, page, or use the DSS buttons to find them. Tell them they have a call holding on line such-and-such, and they would know that they have to select the blinking line.
Back in the day, I used to be the fastest PBX operator in the place, and I just installed them :-) The key was to send it to a station you knew wouldn't answer and it put it out in a holding pattern before it recalled. This was in the day when you could only hold 3 lines at a time, so it worked well when the board got swamped. Today, with colored lights and timed recall, you don't need to do that.
Carl
Jun 24, 2009 | Panasonic BTI KX-T7640BK DSS Console BLACK...
Call conferencing
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
May 11, 2009 | NorStar Meridian M7310 Phone
ANSWERING A CALL AND NON FUNCTIONING ANSWERING SYSTEM
no make or model listed
on many phones there is an ability that when the phone is picked up it is automatically connected to the caller and pressing the answer button is the same as hanging up
as for you second point , if a caller rings but hangs up before the message beep or after the beep but hangs up , there will be no message recorded
Nov 15, 2017 | General Electric 29115AE1 1.9 GHz 1-Line...
I want to be able to answer and hang up my calls w/out selecting a line otr pushing RLS.
whoever services your switch needs to be called to allow for "priority to be given to incoming ringing on going off hook"you could do it yourself if you are familiar with the s/w overlays...hope this helps
Dec 10, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Nortel Norstar 16-Line PBX Speakerphone Logo
155 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
