Question about Samsung SCX-4100 All-In-One Laser Printer
PC Print Pending Message Won't Go Away
Something in the rear of the printer broke during printing. I can manage for now without the printer because what I really need is the scanner. But I can't scan because of the message "PC Print Pending" "Paper jam 2". I would love to delete the pending print job
  • asnundy Dec 19, 2008
    PC Print Pending Message Won't Go Away. The printer was shut for 24 hours. As soon as I put on the electricity the printer started printing multicopies of documents again. I have taken out the papers for now.
    New Friend:
    Problem Solver:
  • 7 Answers
Yes, the article I was looking for. Your article gives me another approach on the subject. I hope to read more articles from you.Blog
Posted on Jul 14, 2017
Have you tried to delete the print job from the computer? After that is done reset the printer by turning it off (30 sec) then on again. If that doesn't work take the paper out and start cleaning your printer with canned air, Q-tips and a cap full of water.
Posted on Jan 05, 2009
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
Not printing nothing in documents pending
If you are not able to print and all your documents go in documents pending you may want to check the following. Go to printer and scanner setting, right click on printer icon and put away the check on offline printing. Now you should be able to print without problems.
Let me know if you solved the problem
Mar 01, 2011 | Lexmark X6570 InkJet Printer
Cuts off printing
Are you having a problem with your printer? If yes, and if the printer stops printing, then it has something to do with the print spooler.
Try the steps below:
On your computer:
Start > Run or Search > type "services.msc" (without quotes) > Enter.
Locate and click the "Print Spooler". Once highlighted in Blue, click the "Stop the service", then click the "Restart the service".
Then clear out the print queue, cancel all pending documents, then try printing again.
Thank you and good luck!
May 15, 2010 | Avanquest Checksoft 2005 (00018059034600)...
Says pc print pending how to cancel the pending
There should be a cancel job **** or a "cancel" button on the printer. Just click that a couple times to remove it.
You can also go into control panel - Printers and Faxes - select the specific printer - manually delete your last print job.
Hope this helps!
Apr 30, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Add Paper / PC Print pending message on LED message
it is problem your printer paper sensor it was broken lever or open
Jul 23, 2009 | Samsung SCX 4200 All-In-One Laser Printer
No response from printer
restart the print spooler service from "services.msc"..also check if your printer works in safe mode or not,if it prints there you must try stopping firewall settings & then try to print..
also delete the pending items to print from the list first...
it it helps,rate my suggestion..
Apr 29, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Document pending will not print
Well this could be a number of issues. First of all try to make sure the printer is on, (yes I know very stupid request but I've seen it happen thousands of times). Then make sure the printer is connected to the PC, either via USB or LPT port or whatever the case maybe. Thirdly, you want to make sure that the printer is installed on the PC. If you goto START/PRINTERS & FAXES, and see if there are any other documents that are stuck or pending, try to delete them out or delete the printer and reinstall it. Then try to print again.
Mar 22, 2009 | Office Equipment & Supplies
Problem getting hp deskjet 6540 inkjet printer to print
shut down the printer and computer both then on only the pc and cancel allthe pending documents from it then again shut down your pc check allthe wires connected properly then on both printer and pc.it will work properly.feel free for further assistance.
Aug 08, 2008 | HP DeskJet 6540 InkJet Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
2,165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
