Televison & Video Logo
A
Anonymous Posted on Jul 12, 2012
Unlock code an tv code for the mitsubishi cs-35301
The tv is just coming an it need an unlock code to enyer
3 Related Answers
Anonymous
  • Posted on Dec 21, 2008
SOURCE: Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
Anonymous
  • Posted on Apr 15, 2009
SOURCE: Unlock Menu
I need a password to unlock my Mitsubishi TV Model # CS40707 Serial # 503994
Martin Smith
  • 80 Answers
  • Posted on Apr 26, 2010
SOURCE: Mitsubishi CS-35301 35 in. rear projection. can't switch inputs
if you have s video connected some tvs wont allow you to use input 1 or 2.disconnect s video cable and try that other wise you got something wrong.
1helpful
Tv lock code, tv is locked dont no code
The factory reset for Mitsubishi television is: Turn the TV on Using the remote, hold down the "9" and the "Q.V." buttons. (for about 10 seconds) The set should then unlock
tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
Security lock on tv dont no code, cant use TV without code
The way to unlock a Mitsubishi TV: Turn the TV on Using the remote control press the "9" and the "Q.V." buttons and hold them down for about 10 seconds The TV should unlock
1helpful
2answers
Mitsubishi CS 35301: No vertical deflection: Is this repairable? Set is ~15 years old. Is it worth repairing? There were no problems prior to this failure.
either your vertical output transistor/I.C. is out or possibly a coupling capacitor is bad,does it try to fill the screen if you tap on the cabinet, if so open up the back and using something like a drink straw prod and push on the board and see if you have just a "cold" solder joint
5helpful
2answers
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
1helpful
2answers
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
3helpful
3answers
Unlock Menu
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
