Question about Sony Handycam DCR-HC32 Mini DV Digital Camcorder
My cassete wount go inside.. Camera not responding
Well, what should I do now.. the cover is open (that cover were the hand strap is attached) and the tape-slide-in system just wont slide in.. The camera is not responding at all.. I tried charging it, and taking the battery in and out... But still no response.. Im pretty confused.. Its just standing on my shelf with that cover open the slider slided out, and the MiniDV cassette poped in.. but no sliding in action further.. Please any advice what should I do.. some mechanical screwing or something to get the tape out.. okey, please tell me what to do..
  • Ernest Bakulis Mar 17, 2007
    m, I could try.. I know a lot from computer hardware (fixing, adding, taking :D).. so I think I could try to manage..
    I would be very pleased, if you spent your time helping some moew..
    * more
    Sergeant:
    Champion:
  • 326 Answers
Hello iQuart, this problem requires certain technical skills & experience. So, in order to have it repaired please bring the camera to the nearest Sony Service. If you still want to do the repair I will try to help you. Please advice. Best regards, Arpi
Posted on Mar 16, 2007
Any idea how to fix it? Is it the sensor or something else?
Open totally the cassete look for paper jam inside that might cover the sensor.
Remove cassete and look for black plastic actuator located on top of paper when cassete is inserted, it might be broken.
If all are ok , press as follow to reset the malfunction [off] while pressing [ Utility/Counter] turn [On] wait till the display appear then [trouble reset] it will appear OK on screen turn OFF/ON main power.
Aug 17, 2015 | Konica Minolta bizhub C250 All-In-One...
I am replacing the lock, what does the plastic rod hanging down from it do and does it need to be attached to anything
It attaches to a pull strap. The pull strap is in case the switch fails it can be pulled to get the door open. Most bosch pull straps are located behind the drain filter cover (lower right).
Oct 16, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Fuji cmaera AV130 how do I attach hand
Kindly attach the hand strap as shown in the attached images:
Thanks for using FixYa.
Jul 04, 2010 | Fuji Rod Repair Kit
How do I attach camera strap to my SL30? Also,
the very thin part of the strap...twist it as you slide it under the bar.You may need a safety pin to catch it and bring it all the way to the other side. take your finger and open the end that you slid through...and slide the handle part through it..and pull.Not sure what bar code you are typing of...
Sep 22, 2009 | Samsung SL30 Digital Camera
The Casset is rejecting back
I got the solution from your net only.Thanks it is wotking presently.you have to do simply take out the cassete and keepp the cassete door open.And then take both the battery out i,e one main battery and another small battery and leave camera in this psoition for two hrs and tehn place back battery in its position and then load cassete .It will work.I have tested it.Thanks a lot.
BK PRASAD
Apr 19, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Need to repair wrist strap attachment on ixus 960
First things first, the small piece that holds the strap, when broken is repairable, but it is best that you dont since there is a strong possibility that the line will give up. the best options you may have to look for are camera pouches that are designed for the camera.
http://farm1.static.flickr.com/186/452068540_bf62b87687.jpg?v=0
http://ecx.images-amazon.com/images/I/51KXXHF3Q0L._SL500_AA280_.jpg
http://farm3.static.flickr.com/2117/2324527140_d133db348b.jpg
Jan 02, 2009 | Canon IXUS 960 IS Digital Camera
Strap
hi clarkent,
  Should you want to attach a hand strap or lanyard to the phone, simply remove the phone’s back cover and lift up the right side of the ‘power’ button’s rubber to reveal the strap hole.
good luck
Jul 03, 2008 | Sony Ericsson K800i Cellular Phone
Help
take off the battery and plug it in to the wall, it it moves or resets then try to close it like you use to, if not make sure the out side cover is open all the way, or if cover is attached to holder try to gently giggle it or see if something is hung up inside
Aug 24, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sony Handycam DCR-HC32 Mini DV Digital Camcorder Logo
88 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
