Apple iPod nano Logo
Anonymous Posted on Dec 10, 2008
I have a ipod nano that stays on a apple screen saver
I have a ipod nano , first off i downloaded itunes to get ready for it , i plugged the USB cable into the right port , and waited about 10 hours , nothing happened , i disconnected the cable , and it stays onto this apple saver , untills the power gets drained out , nothing happens , i use a windows xp computer , ive tried on my laptop aswell , please help !
  • ginni1493 Dec 24, 2008
    Same problem...white apple in middle of the screen with a bluish/grey background...nothing else happens...ipod doesn't function in any way...bought it for our son for Christmas last year and he opened it December 25th 2007...now its December 23rd 2008 and it looks like its kaput...can't turn it off or on and can't get anything to work...ummmmmmmmmm???
Jazz Boyce
Level 1:
  • Contributor 728 Answers
  • Posted on Jan 05, 2009
Jazz Boyce
Contributor
Level 1:
Answers
728
Questions
Helped
191741
Points
64
Try resetting it by first toggling the hold switch and putting it back in the off position. Then press and hold the center button and the menu simultaneously for six to ten seconds and it should work after that.
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Unlock
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
A1199 unlock code
1helpful
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Forgot my code to unlick my ipod
Hi friend, Don't worry.. It is easy to solve your problem. Just follow these steps..
  1. Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC. if you don't have itunes software, get it from here.
  • Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  • Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  • Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code
If you still unable to solve the issue, click here to know more information
Hope it works.. Don't forget to rate me please..
All the best.. :)
1helpful
It is modle a1320 and i fogot the skrean lock pass
  • Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
  • Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    I hope this will help you...
  • 2helpful
    2answers
    My ipod ask for a sercurity code whats that i dnt know wat it is its a nano how can i get code
    2. Step 2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
    3. Step 3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
    4. Step 4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    this should help
    My daughters IPOD NANO is asking for a 4-digit code. She says she didn't set a code for it and I can't find the instructions.
    this should get ya going again
  • 0helpful
    PLEASE HELP! CANT UPLOAD MUSIC TO MY IPOD!!!!!!!!
    uninstall itunes then reinstall it. if that won't fix it uninstall itunes then install winamp (http://www.winamp.com/download).
    if that still doesn't fix it restart your ipod (visit apple support for instructions).
    2answers
    Ipod nano setup assistant
    If you are new to thee ipod then you will have to download the program called itunes at http://www.apple.com
    Top Apple Audio Players & Recorders Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    ZJ Limited
    ZJ Limited
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
