Question about Canon PIXMA iP1600 Printer
I haven't used my printer in awhile and when i tried to print the other day nothing printed. do i need to clean something or what can i do to get it to work? the ink tanks are full of ink.
    Scholar:
  • 68 Answers
Chances are the ink cartridges have dried up. Depending on your printer, you might be able to run some cleaning tests, but I would bet you need new cartridges. If you do not use your printer very often, I recommend removing the cartridges and placing them in a baggie or plastic wrap to keep them from drying out.
Posted on Dec 10, 2008
Printing blank pages
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 11, 2013 | Canon PIXMA Pro9000 InkJet Photo Printer
I have an Epson Stylus NX100, that worked fine about a month ago. I needed to get something printed off and when I attempted to print, the paper went through and it went through the motion of printing but...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 10, 2011 | Epson Stylus NX100 InkJet Printer
HP 7780 suddenly stopped printing in red. I have changed the cartridges several times. I am using brand new HP cartridges. Have cleaned the print heads, aligned several times, nothing has heled. The...
Hi Good day!!!
Maybe your print head is clooged (red)
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like print head cleaning solution
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realizing the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and print head cleaning solution injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Thank you for using fixya
Jan 03, 2011 | HP Office Equipment & Supplies
Color is low but cant print black on printer paper runs through blank
good day, if nothings coming up then u might need to run a maintenance check, use cleaning then test print and see if somethings changed. hope this helps, have a nice day
Feb 07, 2010 | Canon PIXMA MX310 All-In-One Printer
After replacing cartridge in dell 810 the colours printing wrong
Hi
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
MIXED COLOURS
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
PRINT TEST SHEETS FOR USE WITHMagic Inkjet Flush
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
Clogged printer head on Kodak 5300
Call Kadak Customer Support. They will send you a replacement print head. I have already had to do this twice in about a year and a half. Tell them that you have run all of the tests or they will have you try it again. But in the end they will send you a new print head in a couple of days. This is the only thing that will work.
Aug 15, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP 812C will not print yellow but everything else is A-OK Repeated cleanings have NO effect. Cleaned contacts on printer where it connects to cartridge, no effect. HP 23 cartridge only has about 10 pages...
HTML clipboardHi,
It you haven´t used your printer for a while It sounds like the yellow has clogged up in the print head.
Although you have ink you need to print something regularly about every 10 days to keep the tiny jets open
otherwise it´s like trying to pass a camel through the eye of a needle.
So the inks may have clogged up?
The empty weights are 65g C6615A [No. 15] black and
90g C1823A color ink cartridge
anything over that... 1g = 1ml of unused ink.
So if you still have ink you can easily unclog it with a HTML clipboard Magic Inkjet Flush Kit (find it on Ebay)
Or you can read more here:
Good Luck!
Tinteiros (Ebay)
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
Epson RX650 with a G5 Mac. Printing beautifully,now pgs are blank
It definately sounds like blocked print heads, try head cleaning 4 or 5 times, leave overnight and try another 4 or 5 times the next day. This usually works, if not you will need to try something a little bit stronger. Try this link:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Blocked print heads are more far more common if you are using non-genuine Epson inks. Please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
MFC210C can't print in blck
I had a similar problem. The printer had indicated that it was out of black ink. I didn't have one on hand, so, for more than a week I couldn't print anything, because if you are out of any one of the four ink cartridges, it won't print at all. That delay in replacing the black ink cartridge apparently was enough time for the printhead to dry out. Big Mistake! I contacted Brother's Tech Support and they suggested I run the cleaning cycle and try to print a test page. Still nothing printed. They had me run another cleaning cycle, and another, and another. Finally, after the fourth cleaning cycle, something started to show up on the paper. They had me clean it two more times, six in all, and it was back to normal. From now on, if it says one of the ink cartridges is empty, I change it yesterday. The major disadvantage of all of this, other than not being able to print for awhile, is that this procedure used up about 1/2 of a brand new black ink cartridge.
Oct 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black and yellow ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
old marine
old marine
Corne Viljoen
