Question about Hitachi Office Equipment & Supplies
How to clean air filter on a Hitachi CP-X345 LCD Projector
I got a Hitachi CP-X345 lcd projector. I know where the filter is and how to get the grey thing out. You know - first you remove the cover - light grey plastic and underneath that there is this dark grey filter.  I have gently washed it with a wet cloth - also the rest of the projector from outside. Then i left it for some minutes and then i resampled it. But it stills says the same thing and the bulb where it says "Temp" (temperature i guess) is red.
So how do i clean it so it doesn't say that i need to clean it?? Shall i use canned air?, wash it under war/cold/normal water for some time and then let it air dry / do it myself? Hope you understand and you are able to answer quick. Thank you.
- you may use movie or text but if you are able to use a movie it would be super!! - i noticed that many more have the same problem but none of them got solutions.
Andreasstrandgaard@hotmail.com
  • 3422 Answers
SOURCE: Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Posted on Feb 25, 2008
Marrie
  • 563 Answers
SOURCE: reset
Hi there
Check if both your filter timer and lamp timer is reset.
If it is then there is a Mainboard fault and it will need repair or replacement.
Posted on Mar 26, 2008
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
fredcause
  • 51 Answers
SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Posted on Dec 08, 2008
SOURCE: Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
Posted on Apr 21, 2009
It says to Check the air flow
Open the cover. At some ends there will be 'filters', to clean the air entering the projector. If these filters are blocked with dust or lint, air flow will be blocked.
Clean any dust from these filters. Close the cover and check whether your problem is solved.
Sep 14, 2011 | Hitachi CP-X251 LCD Projector
Lcd projector displays the message check air flow
Hi....
Clean the filter
It will show you in the manual
Apr 23, 2010 | Hitachi Performa CP-RS55 Multimedia...
Lamp and temp blink red
Check your owners manual. This means that the air filter needs to be cleaned or that the projector has become too cold. My guess is the first one. The owners manual has instructions for cleaning or replacing the air filter :)
Feb 05, 2010 | Hitachi CP-X260 LCD Projector
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP-X445W Multi. Projector
I have the same problem with a Hitachi CP-X345 Multimedia Projector. My Acer Aspire 3630 Laptop cannot be detected but it works without incident with a Dell Vostro 1500; just plug and play. Desktop settings to second screen doesn’t seem to help.
May 16, 2008 | Hitachi CP-X345 Multimedia Projector
How to clean air filter in HITACHI CP-X385
Hi there
Look at the bottom of the Projector , you'll see a thin grey line with two edges on it. That is the filter. Grip on the sides and gently pull it out.
Mar 17, 2008 | Hitachi CP-X385W Multimedia Projector
Picture quality
Se if the lens, are clean or the dust filter.
Nov 09, 2007 | Hitachi CP-X345 Multimedia Projector
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
1,267 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
